Reomving Turbocharger from 2000 S80 T6
sparro
Year and Model: s80 2000
Post by sparro »
Could anyone provide step by step instruction or some points? How hard is it? Thanks.
Mark27
Year and Model: S80 2003
Post by Mark27 »
I do not know how to upload documents so here's a copy and paste job from chiltondiy. Sorry the Pictures will not paste:
6-Cylinder Engines
Before servicing the vehicle, refer to the Precautions section.
Remove or disconnect the following:
Engine stabilizer brace
Air charge pipe
Air intake pipe
Heat deflector plate
Drain the cooling system
Rear Side Impact Protection System (SIPS) member
Heated oxygen (HO2S) wiring connectors
Catalytic converters
Right half shaft
Turbo coolant pipes
Turbo oil lines
Turbocharger
Mounting bolt locations for 6-cylinder turbo
Click to Enlarge
To install:
Install or connect the following:
Turbocharger and tighten the fasteners to 18 ft. lbs. (25 Nm)
Turbo oil lines. Tighten to 28 ft. lbs. (38 ft. lbs).
Turbo coolant pipes
Catalytic converters with new gaskets. Tighten fasteners to 18 ft. lbs. (25 Nm).
Rear SIPS member. Tighten to 18 ft. lbs. (25 Nm).
Right half shaft
Heat deflector plate. Tighten to 18 ft. lbs. (25 Nm).
Air intake pipe
Air charge pipe
Engine stabilizer brace. Tighten the bolts at the suspension turrets to 37 ft. lbs. (50 Nm). Tighten the engine bracket bolt to 59 ft. lbs. (80 Nm).
Fill the cooling system.
Start the engine and check for leaks.
Before servicing the vehicle, refer to the Precautions Section.
Air charge pipe
Air intake pipe
Right halfshaft
Turbo coolant pipes
Turbo oil lines
Turbocharger
Click to Enlarge
To install:
Turbo coolant pipes
Right halfshaft
Air intake pipe
Air charge pipe
sparro
Post by sparro »
Thanks. Looks very difficult to do for me...
boosted5cyl
Year and Model: '98 V70 T5, '99 S80
Post by boosted5cyl »
Its not too hard, its just "fiddly" but it also depends which one. So...Which one? Are you replacing a full unit?
'04 XC90 2.5T AWD (Angus) 134K.
'99 S80 T6 (Medusa) 214k. On borrowed time LOL
'98 V70 T5 (Vivienne). RIP @ 228K. Spun rod bearings.
sparro
Post by sparro »
My S80 is leaking oil in many places. My mechanic thinks turbochargers are leaking but did not recommend work since it costs too much by his labor rate. Besides I have cam seals leak and front crankshaft leak. The big one is from the turbocharger(s), according to him. He thinks they should be replaced. (Not sure whether it is from one or both.) I agree.
If I can keep the car in my backyard and remove piece by piece, I may be able to do it. If anyone could show basic steps with photos, it would be a big help. I was able to do spark plug change based on instruction from this website (thanks!)
boosted5cyl
Have you serviced the PCV system yet? If not, dont bother doing any oil-leak related work until that is taken care of. Clogged PCV can cause oil leaks like you mention. If its still clogged, you will end up re-doing all of your work as they will continue to leak! Checkout the repair section for the PCV service. Then we can come back to the turbos. You may still need to replace some seals, but at least with the PCV service done you wont blow them again!
sparro
Post by sparro »
Yes. But I will double check. (How do I do that?)
About 2-3 years ago (15000 miles ago), there were smokes/fumes coming out from the top of engine. So I took it to the dealership. They did the PCV cleaning service for $300. So I am assuming PCV is OK.
This time, there was no fume/smoke coming out. My car is being driven as strong as ever. I do not feel any lack of power. I do not smell any oil burning. I do not see any smoke anywhere.
It is just that oil leaks in many places. Several oil drops happen whenver I park the car. I am puzzled. Accoring to the mechanic, more drops come from the turbocharger side.
boosted5cyl
OK, so recheck the PCV to be sure (glove over diptstick test). I think next step is to get some brake cleaner\degreaser and clean the turbos and piping. Find out exactly where the oil is leaking from. Most common place is the oil return pipe either on the turbo or block end. In that case, you wont need to remove the turbox, so fingers crossed thats all it is. I think its pretty rare for an actual turbo unit to leak oil externally without anything getting into the engine in some way as well.
From what you describe I think you are in pretty good shape, probably just need to replace the oil return gaskets and orings. Parts <$10, fiddly job though.
sparro
Post by sparro »
Thank you. I will try it.
sparro
Post by sparro »
Yesterday, after driving a while, I parked the car idling. I took out the oil dipstick. There was no smoke coming out. Then I put my foot on accelerator. Then white smoke came out. Also only when I put on accelerator, white smoke came out of the exhaust pipe (muffler) in the rear. I am not sure whether this is the sign for clogged PCV. I would appreciate anyone's comment. Thanks.
