V40 1.9T Fuel Filter Location. :?:
1996 - 2004 S40
1996 - 2004 V40
Nkisi_Nkondi
Year and Model: 2002 V40 1.9T
Post by Nkisi_Nkondi »
Hello,
I would like to know the location of the fuel filter and also maybe some info on how to change it.
Anything info will help. Thanks!!
zulu-v40
Year and Model: 2003 V40
Post by zulu-v40 »
On my 2003 v40 the fuel filter is located on the driver's side, same side as the gas tank, just forward of the rear axle. There will be a plastic guard shielding the fuel filter. I recommend spending a few dollars more and purchasing a Bosch or Mann OEM replacement. Just make sure the part is OEM or you risk leaking fuel.
Below is a nice write-up on the process.
matthewsvolvosite.com/forums/viewtopic.php?f=1&t=31420
The tricky part is removing the filter. Either side has 'quick-release' connectors. The left side has a button that must be depressed to remove the line. The right connector will require a tool that can fit in between the nipple and the quick release. I used a small pair of scissors to push the connector away from the filter. Once you actually get underneath the car and see for yourself it will make sense.
*Use the rubber covers from the new filter to stop fuel from exiting the old filter.
*Have lots of towels handy.
*You can depressurize the fuel system prior to doing the job, which should reduce the amount of fuel that leaks. I did not and the leakage was minimal.
2003 V40 T4, silicone vacuum hoses, K&N air filter, iPd Boost Gauge, iPd HD TCV, PowerSlot Rotors
Daddy cool
Year and Model: v40 1.9T 2000
Post by Daddy cool »
Yep zulu-v40 is right. The filter is just forward of the rear axle.
