While my sweetie was dealing with the battery on my 2000 V70 XC he found a chunk of rubber between the battery and the air filter housing. (NOT the cabin air filter!)
I cleaned it up and researched the part # (1336404) -- it is called a "buffer" and it's supposed to go between the air filter housing and the side of the engine compartment.
How to I remove the air filter housing so I can get this buffer part back in? I know how to change the filter, but this is something different, and I couldn't find it on the site anywhere.
How to REMOVE Air Filter Housing to replace "buffer"
Susans_Volvo
- Year and Model: V70 XC AWD 2000
- Has thanked: 312 times
- Been thanked: 818 times
If it is like the 850, the air filter housing just lifts out.
Once you take out the cover, air filter if you want to, and remove any hoses attached (keep track of where they go), there are 4 little expanding posts that snap through holes in the housing. They are around the outside of the filter housing. You can pinch them together with a small socket like maybe 10 mm, or just pull up sharply the housing will dislodge from them. There is also a post that sort of braces into the fender well, but it pulls right out of there.
- 8689 Views
Last post by ThommyKent
- 12735 Views
Last post by JudgeRat
- 1519 Views
Last post by t1adler
- 1709 Views
Last post by Sydt
- 2495 Views
Last post by MoVolvos
