1997 960 crankshaft timing mark - where is it?
bskeels
- Year and Model: 1997 Volvo 960
- Been thanked: 3 times
I am in need of help locating the timing mark for the crankshaft of a 97 960 engine, I have accidently moved the crank after the belt was removed. I cannot find any lines or marks on the pulley. Can anyone help?
The Fleet
2012 Ram 2500
97 Volvo 960
98 V70 AWD (208000+)
66 Volvo 122s sedan project
98 Volvo V70 XC (151,000+) parts car
08 Volvo V50 T5
"Human history becomes more and more a race between education and catastrophe" - H. G. Wells
2012 Ram 2500
97 Volvo 960
08 Volvo V50 T5
JDS60R
The cam belt rides on the toothed pulley that has one or two small cut notches in the teeth placed closest to the engine. The easiest way to find them is to look on the piece of metal directly attached to the toothed pulley on the crank pulley side ( away from engine). Their is a small bump on that area as well.
Search for timing marks on Whiteblock and you will see some photos of the marks.
https://www.matthewsvolvosite.com/forums ... =9&t=27078
Retired
Here is a picture of mine, when it was off the car and shot from the backside.
When the crank is on it's mark, then you will be able to rotate both cams freely without interference. Many people mistake that on the mark means TDC for the number one cylinder, but it does not, it means that all pistons will be at various levels below the deck to allow for cam rotations.
DanR '94 964 360,000 miles (126,000 on the new engine)
- crank timing mark.JPG (40.5 KiB) Viewed 1671 times
- 1211 Views
Last post by Ozark Lee
- 852 Views
Last post by bmdubya1198
