Window Switch Replacement How To -- excellent!
This topic is in the MVS Volvo Repair Database » Replace Volvo Window Switches: S70 & V70
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
Courtesy of aj98s70, we have a very thorough How To on replacing window switches for S70 and V70 models (and maybe some others -- please comment if you know).
https://www.matthewsvolvosite.com/window ... eplace.php
Here's an image from that page:
Thanks aj98s70!
Also -> Amazon link
Guest
Post by Guest »
I have made a few posts on this issue in boards here and there, anyway after you have read the instructions on how to get your SW out, and if you have ventured as far as pulling the SW apart to find the orange plastic slider has a nice divet in it from being melted by the copper contacts..... Then..... this is what you do next.
Gently pry up the 4 copper contacts, the orange plastic slider will pull out. Go and buy yourself a new tube of SuperGlue with a fine nozzle. Fill the divet & let it dry repeat until the build up of the glue is domed, gently trim flat again with a razor. Re-install in SW. The offending contact will be visibly blackened or worn down from arcing, cleaning it goes without saying to restore connectivity. If you left this too loing you may have fried the circuit, in which case unless your a better electrician than I am, it's time to head down to Volvo to buy your new SW. The culprit I suspect is the excessive electrical load put on the SW by the underpowered door motor dragging a heavy window up & down, thus heating the contacts up. If you ever have reason to have the door liner off at any stage a clean of the window regulator motor would be a wise prevention step, and is very accessable
Cheer
OZ
jstuebing
Post by jstuebing »
Thanks for a fantastic explanation. The description of the problem and the pictures were great. John
matthew1 wrote:Courtesy of aj98s70, we have a very thorough How To on replacing window switches for S70 and V70 models (and maybe some others -- please comment if you know).
Thanks aj98s70!
Pat
Post by Pat »
Great description of the "how to." I actually had the entire inside door panel off last night before I figured out the switch module pops out. I may use the super glue method and get a few more years out of the old switch unit.
One question - will the defective driver side window switch affect the operation of my power rearview window and sunroof?
Thanks.
jack
Post by jack »
:P
Great Article- As I was about to remove the entire door panel, I found your article. Thank-You. Great Pictures and explanation. Time is money. You saved me both!
Thanks!
Jack
Guest
Post by Guest »
Matthew,
Thanks for a fabulous how-to. Volvo should be mightily ashamed of this car series in the years 98-00. Mine has failed like clockwork on the same things that fail on everyone else's car - ABS module, lock modules, PNP switch, power window switch etc... and it only has 40K miles on it !
girls4martino
Post by girls4martino »
Hello everyone;
I have my curtesy lights that sometimes stay on after the door is closed.
I suspect it may be a door switch problem that should be actuated when the door is sensed closed. If the door is slammed shut it will work the lights okay. I don't know where to look for this switch if it exist. Anyone have info.
Thanks
Ralph :(
tgerckens
Post by tgerckens »
Thanks so much for this detailed piece! You saved me about $100 on this repair, and the description of how to get the window up using a screw driver allowed me to drive the car until the part came in from the e-bay auction.
Many thanks!
aj98s70
Post by aj98s70 »
I am glad the instructions came in handy..
Dont forget to thank Matt for providing us a forum to share information..
-ajay
1998 S70 GLT ~72k
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
aj98s70 wrote:I am glad the instructions came in handy..
-ajay
If you really want to thank him, buy things from Amazon through his link here or make a donation...the PayPal tab is at the top of this page.
