Hey, guys. I have finally tried out the obd I on my 95 854 because my check engine light came on over the weekend, went out for a few days, and returned today. The code I got from the A1 port is 322 (wrong gear value). I cleared it, and it hasn't come back on yet. So, several questions:
-Check engine initially came on when I put it in sport mode and drove aggressively in the NC mountains (sat for one day, didn't come back on driving normally the next day). Would that have caused a funky gear value issue? I have had problems with the pnp in the past, but so far have only "quick shifted" it fixed.
-What are the other ports in A for (2-7) and should I be reading them, too?
Thanks.
1995 854 169k
1998 v70 166k
Reading Codes 850
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Yeah, the PNP will cause that code. You need to go in there and rebuild/clean it - ratcheting the shifter back and forth will only work for so long.
A2 and A6 typically store "check engine" light codes.
Here's a full list:
A1 Transmission
B1 Climate Control
A2 Fuel System
B2 Cruise Control
A3 ABS
B5 SRS
A5 TCU (Transmission Control)
B6 Power Seat
A6 Ignition System
A7 Combined Instrument
Here's a full list:
A1 Transmission
B1 Climate Control
A2 Fuel System
B2 Cruise Control
A3 ABS
B5 SRS
B6 Power Seat
A6 Ignition System
'98 S70 T5
2016 Chevy Cruze Premier
Gentleman Mac
- Year and Model: 850 1995
Great, thanks for the info.
Do you think it's better to clean it or replace it altogether?
jblackburn
Most of the contacts should still be good; just need to be cleaned up.
'98 S70 T5
- 18 Replies
- 1412 Views
Last post by BeerDeer
- 674 Views
Last post by Luciendar21
- 11923 Views
- 1518 Views
Last post by esl_97_850_T5
- 585 Views
