After noticing the odd waft of fuel around my '95 850 turbo i read up on the "common" problem of cracking/weeping around the heat shield lugs. I got underneath and found a wet track coming from a lug.
I have removed the tank (whew) and found i have stress cracks around 2 of the 3 lugs.
Getting a new tank here in NZ would cost more than the car is worth so i am looking for repair recommendations.
Plastic welding or chemical sealing seem to options, i am leading toward plastic welding, mainly because no one seems to stock a chemical solution. (or know what type of plastic it is made from )
Any tried and true remedies?
Then i will need to find an alternative way to mount that heat shield.........
'94 fuel tank - repair possible?
christhekiwi
- Year and Model: 850 Turbo X 2
confused_al
- Year and Model: 1996 TLA wagon
Have you seen Lee's report?
https://www.matthewsvolvosite.com/forums ... 09#p208009
Sounds your gas tank should be covered by Volvo's recall.
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
elchopperfreak
- Year and Model: S70 T5 1999
I found the hard way, about a sealer they use for barges and ships, the shipping company somehow cracked my gas tank getting my truck on board, they put that epoxy there ( gas and al) and it sealed quick, its been a few years too.
Might try JB weld if available in NZ and cant find the miracle ship epoxy..
I might find the name with a couple calls..let me see.....
christhekiwi
Thanks, Yes i have some JB Weld. Am going to ask the dealer about the recall mentioned but i get the feeling this will not be an option in NZ. I woudl appreciate the name of the product you used if you can find it . Thanks.
christhekiwi
I have got as far as the national service manager and await his response.confused_al wrote:Have you seen Lee's report?
It is a shame that the service given by the dealer here seems designed to discourage me from ever owing a new Volvo.
The options are; either pay the approximate current value of the car for any significant repair, or scrap the car.
Local dealer price for a coolant expansion tank $275. Price of after market unit from Pelican Parts in USA approx $40
Marcobrick
- Year and Model: 2003 V70T5
- Has thanked: 3 times
I hear you Chris! I have never bought anything except a set of spark plugs for my car from around here. Sometimes when I want a laugh, I phone my local dealer for a price on something I need, and I have only once gotten them on the phone, most of the time they have it go to answerphone! I have over the last 12 months spent probably $2k on parts from FCP for 3 Volvos, and the service has been great and even with the punitive cost of freight it still comes out to half the price and often less.
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
1973 Land Rover Series 3 flat deck.
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1995 850 Turbo Wagon
1998 V70T5
Favourite line: "How hard can it be?"
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1998 V70T5
christhekiwi
Well i gave up waiting for Volvo NZ and completed a repair using JB Weld.christhekiwi wrote:Thanks, Yes i have some JB Weld. Am going to ask the dealer about the recall mentioned but i get the feeling this will not be an option in NZ. I would appreciate the name of the product you used if you can find it . Thanks.
Fitted a garden hose to the fuel line to the rail, jumpered the FPR and ran the fuel into my "other' volvo.
Removed the sender, pump, tank.
De-greased the area around the heat shield fitting points - all were cracked and leaking.
Sanded around these points with 60 grit and thoroughly keyed the surrounding area. Applied JB Weld.
I left the repair for 3 days to cure then tested. All good.
Re-fitted heat shield using the two upper fixing points only - (to reduce diagonal stress?)
Fitted rubber grommets between each fixing and the shield. Refitted everything.
During this job i found one end of the 15mmm line was also split and just starting to leak.
Notes;
1 Fit the collar to the pump before fitting the lines
2 Fit the smaller 15mm (return) line that goes to the spigot at the top of the tank before re-fitting the tank due to poor access from the top.
3 Fit the heat shield before re-fitting the tank.
4 Note the direction that fuel is running before you connect a hose to drain the fuel otherwise you will drench the engine with gas when you fit the jumper.
