Lifting car
VolvoMonkey
Year and Model: V70 XC 1999
Lifting car
Post by VolvoMonkey »
This seems like such a basic question, which probably explains why I can't find an answer elsewhere. I've never needed to lift both ends of the car; is it okay to hold it up on 4 jack stands or should I be using ramps?
Thanks
Choguy03
Year and Model: S40, 2000
Post by Choguy03 »
Four jack stands are just fine. Just be sure to use proper jacking points and place the stands on the frame. Ramps just take out having to jack up the front of the car.
VolvoMonkey
Thanks for the quick reply.
VolvoTurbo850
Year and Model: 1994 850 (T5)
Post by VolvoTurbo850 »
As per the other poster, Jacks are good.
Call me cautious but i also land up putting the trolley jack in position to where i am working.. just in case.
The Fleet
2001 V70 (NA) 2.5
1999 C70 Conv. Turbo 2.3 HPT
1998 S70 Turbo (T5) SE
1994 850 Turbo (T5)
1980 Corvette (Corvolvo)
Previous Possessions: (4) 240's, (1) 740, (9) 850's, (5) 70 Series
Projects on the go: NONE... Yet!
VolvoMonkey
Yep, better safe then sorry. Cellphone is always close by too.
Year and Model: 2004 V70 2.5T
Been thanked: 472 times
Post by cn90 »
1. For simple jobs (Engine Oil Change, ATF drain/refill etc.), WOOD RAMPS work great.
Search forum for ino that I posted.
2. If you need to lift the car for brake job etc. Use Jack Stand (No Jack, Jack Stand only)!
This thread below has info on where to place Jack Stand.
Safety first!
The bottom line is to find the SUBFRAME and place Jack Stand there.
http://forums.swedespeed.com/showthread ... ive-answer
newowner
Year and Model: V70,S70,850,C70 98
Post by newowner »
Along the same lines: could I use the scissors jacks, one from the car I'm lifting and another from my 850 to lift each side at the same time. My goal is to get the entire car on jack stands for some exhaust work, and leave it on the jack stands for the winter.
Thanks in advance,
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 93 times
Been thanked: 146 times
Post by BEJinFbk »
I've had mine up on all four several times. Solid as a rock.
In the air.jpg (39.38 KiB) Viewed 2546 times
I use a floor jack with a modified chunk of 2 x 4 to lift the
car at the factory scissor jack point and do one side at a time.
Just chock everything and move slowly and carefully.
A jack stand tweek that I've picked up on over the years
that make me a little more comfortable about preventing
the car from slipping off of the stands is hockey pucks.
A puck atop each stand provides a better grip that's
less likely to slide and also provides a little dampening.
At the front, there are shop lift locating pin openings in the
plates that join the sub frame to the unibody structure.
The pucks help lock the jackstands in between the bolt heads that
secure the plates there. Also prevents the plate from deforming.
This is the only pic I've got, but I uploaded big to allow zooming:
At the rear of my AWD are circular jack points for shop lifts
just ahead of the rear axle. I use those points for the back.
Hasn't fallen on me yet! ( Knock on Swedish simulated wood...)
And YES - Those worn out Good Years have been replaced! :lol:
