jumped timing
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
volvoman230
Year and Model: 740gl 1990
jumped timing
Post by volvoman230 »
i have 1990 volvo 740gl b230f. car jumped timing.i have all gears set at tdc.rotor will not point to number 1.i pulled distributor ,cant get rotor to point to #1.help please!
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Have you got #1 piston at TDC?
Remove all of the plugs and put your thumb on #1 plug hole. Turn the engine by hand and when you feel pressure on your thumb you are on the compression stroke of #1 piston. To get the piston spot on TDC put a long piece of plastic (a knitting needle is ideal) into the plug hole and continue to turn the engine. The plastic will come up until the piston reaches TDC and will then start to go down again. Turn the engine back until the plastic is at its highest point. The distributor rotor should now be pointing at #1.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
volvoman230
im already at tdc.crank gear aligned,cam aligned,also done compression on # 1 to make sure.rotor points down away from #1
