'90 740 GL: Pressure test heater core?
Schumi 1
- Year and Model: 1993 940 Estate
I'm about to do mine, I was told you can rig a bicycle pump with some hose fittings and a bypass cap, and submerge the new core in water to test for leaks. He said about 20psi is all you need. Otherwise, you can take it in to a shop that can test it for you.
If you are repacing the heater hoses, make sure you use OEM , I have found the aftermarket hoses to be greatly inferior.
Good luck
Good luck
- 11 Replies
- 9842 Views
- 5082 Views
- 32 Replies
- 17724 Views
Last post by sleddriver
- 1408 Views
Last post by Salomons Driveway
- 14 Replies
- 3622 Views
Last post by precopster
