What type of DIY'er are you?
I check fluid levels or tire pressure
0
No votes
I change wipers
0
No votes
I change headlight/taillight bulbs
0
No votes
I change oil, transmission fluid
0
No votes
I change brake pads, rotors, serpentine belts
2
8%
I change suspension components like control arms
1
4%
I change axles, PCV, timing belts
12
48%
I do top or bottom-end engine work
9
36%
I am/was a certified Volvo tech or ASE technician
1
4%
Total votes: 25
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
Also -> Amazon link
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
PCV and Timing belts are NOT on the same level.
Just sayin ;)
'98 S70 T5
2016 Chevy Cruze Premier
matthew1
Site Admin
Post by matthew1 »
jblackburn wrote:PCV and Timing belts are NOT on the same level.
Just sayin ;)
You had your chance for input in the moderator lounge! :D :P
(I know you had a hellish time with your TB, and that's a shame. Luck of the draw?)
Also -> Amazon link
FCPEURO
Year and Model: 2006 XC90 V8
Been thanked: 19 times
Post by FCPEURO »
I will do everything I can on a car as long as I have all the correct tools.
Sent from my LG-P999 using Tapatalk
obayha
Year and Model: V70 1999 Base
Been thanked: 2 times
Post by obayha »
I put my DIY in my sig line and thank the one who gave the best write-up.
PCV and TB change are pretty close to the same, as long as you don't throw in changing the seals also, with a 14 inch drill :roll: .
Did struts also before joining this forum. I thanks someone higher up on that one. Had no idea what I was doing.
Shane
1998 V70 T5 331,000 :( Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
Matty Moo
Year and Model: 850, 1996
Has thanked: 1 time
Been thanked: 30 times
Post by Matty Moo »
I'll do anything BUT rebuild an engine or transmission. Everything else is nuts, bolts and using your head...and having the right tools.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
RBH
Year and Model: 1999 V70
Post by RBH »
I have never needed to rebuild a Volvo engine or head. When I first started driving Volvos I got a core engine with the idea of rebuilding at my leisure preparing for what I thought would be the inevitable. It hasn't happened yet. You might ask why was I so concerned about having a spare motor ready. In my past I had another "V" car..... Chevy's Vega. I also had an overly stubborn attitude about making the car last. Rebuilding, decking the block, etc. were regular activities. The car was a superb course in how to repair everything and often!
1999 V70, 1993 940, 1992 740, 1990 740
Billc1015
Year and Model: 1994 855 turbo
Post by Billc1015 »
I have pretty much done everything except body work. Granted I was a tech at a Volvo dealer for a few years and I am currently a tech at a Subaru dealer so I have just about all the tools I need as well as a lift to work on.
I am here: http://maps.google.com/maps?ll=40.334585,-75.130858
FCPEURO
Post by FCPEURO »
Matty Moo wrote:I'll do anything BUT rebuild an engine or transmission. Everything else is nuts, bolts and using your head...and having the right tools.
I will break and engine down and that the block sent out to be done, but I will not try and bore it myself. It is just better to have a pro do that. I am also with you on the transmission too, but I think I would try it if the car was not a DD.
