s70 glt exhaust, chip, and gains
How to go faster, stop quicker, and turn harder. Chips, exhaust, larger turbos, bigger/slotted/drilled rotors, high performance brake pads, manual boost controllers, performance shocks/struts/springs, airbox mods and more! Also discussion on HID and Xenon lights, aftermarket foglights and other exterior lighting.
s70glt novice[Will]
Year and Model: s70 glt 98
Post by s70glt novice[Will] »
Well, christmas s rolling around and i was wondering what new exhaust i should get for my glt. I would love the racing cat of IPD's but their price is wayyyyy too much for me. its close to a thousand. i was wandering the internet and came across obx exhaust. watched some videos and it sound great. but heres the kicker: obx's exhaust doesnt come with a cat and i live in california where they smog test. apart from that, i dont want to be blowing huge amounts of poisoness chemicals around. :(
So what can i do? are there any other exhaust that come with a cat? can i buy a good high-flow cat for less then 500? or is ipd's exhaust the best bet? i would like to have enough money left over for an ecu, which is why im getting the exhaust, might as well ask this too; do i get more HP and torque if i put a better exhaust on when paired with a tuned chip? darn, now this question too, lol; best chip? i know ipds is good, but ar there any others that are comparably priced, but better? whew. sorry :lol:
thanks!
'98 s70 GLT-127k
ARD Green, obx, 16t, other go-fast parts
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 93 times
Been thanked: 146 times
Post by BEJinFbk »
Let the exhaust wait. The ECU will be much better bang for your buck.
s70glt novice[Will]
but with the exhaust, wont the ecu have more gain? and if i get it after the ecu, will i need to get it re-tuned?
'98 s70 GLT-127k
charlyW
Year and Model: 97 855 T-5 CD
Post by charlyW »
Unless you do the entire system you're not going to see much gains above 20bhp to get some serious gains you'd need
Racing cat 100-300 cel
Better injectors blue/green or black
Higher pressure fuel pump to deliver more fuel
faster cams
free flow airfilter
full service
full stainless exhaust 3inch bore minimum
Larger Turbocharger
obviously this cost a lot of cash but the ECU will give a better pickup along with a small gain in power/torque
855 T-5 RHD Blue: MBC, Custom Map based on Rica, K&N Filter, 18T Turbocharger, White/Green injectors [depends on my mood], Blue Silicone vacuum hoses
s70glt novice[Will]
okay, thanks. ecu it is then
'98 s70 GLT-127k
s70glt novice[Will]
so, if i have enough cash for an ecu AND exhaust, why shouldnt i get both? i would really love to listen to that every day...
'98 s70 GLT-127k
s70glt novice[Will]
And the exhaust has to have some more gains then just stock.
'98 s70 GLT-127k
gilhuly
Year and Model: 98 V70 GLT
Post by gilhuly »
Injectors, fuel pump and cams are unneccessary for 90% of the typical mod levels on 850 turbos. You have a low pressure turbo. You need a bigger turbo then you can simultaneously do exhaust (3"dp, 2.5" cat back) and a chip for that setup. Figure out which turbo you want (15G, 16T, 18T, 19T) and then buy an appropriate dp (flange type) and exhaust and then get an appropriate chip/ecu.
Doing a chip first for an S70 LPT might not get you what you're hoping for. Plan it out in the order above and I think you'll get maximum benefit before entering a much more expensive level of cost benefit that involves serious engine mods.
1998 V70 GLT, 15G swap
Fairfield, CT
s70glt novice[Will]
i see. so i basically should be doing this to a t5? and i still want it to be a daily driver, just with a little more kick and better sound :)
'98 s70 GLT-127k
BEJinFbk
Post by BEJinFbk »
