S60 suspension issues
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
iwritecopy
Year and Model: S60 2002
Post by iwritecopy »
Hi guys! 2002 S60 2.4 150k...heard this squeaking from the front end every time I would hit a bump. Opened the hood and found the tops of both struts poking out of the rubber grommet - in the center of the three bolts where the strut comes up to the wheel well. The front struts were replaced professionally about 2 years ago...what are my options? Thanks so much! Pic attached.
Dave
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Looks pretty normal to me
Take a wrench and try to twist the top nut
If they're not broken they will only move a hair, (1/4"+ or so) if either spring seat is broken you will be EASILY able to turn the nut 360 degrees
iwritecopy
I will check that, thanks JRL!
JRL
Post by JRL »
You obviously have to pop that nut cover off first
iwritecopy
Hi JRL, it is easy for me to turn that nut...now what? What needs to be replaced? Thanks, and a happy Thanksgiving today to all! I'm VERY thankful for this forum!!
otis44
Year and Model: 2006 S60 T5
Post by otis44 »
Spring seats are what you need to replace. Many people use the seat made for the XC90 as it is supposedly more durable, there may be some good ones aftermarket as well such as from IPD. I think there may be a tutorial on here somewhere regarding replacement if you are intent on doing it yourself.
iwritecopy
Thanks much...spring seats it is then. Thank you so much!
iwritecopy
oh, one more thing please - I can replace the spring seats with the strut assy in the car, right? I don't have to remove anything to replace the spring seats? I saw the video that was mentioned with the entire strut assy on a work bench. Thanks!
otis44
Post by otis44 »
iwritecopy wrote:oh, one more thing please - I can replace the spring seats with the strut assy in the car, right? I don't have to remove anything to replace the spring seats? I saw the video that was mentioned with the entire strut assy on a work bench. Thanks!
The strut has to be removed to replace the seat. If you're not familiar with compressing and dealing with the springs it might be a job best left to someone else. This would also be a good time to examine other suspension components while everything is apart. At 150k I'd bet the end links and and possibly other pieces are shot as well if they haven't been previously replaced.
iwritecopy
Ok, thanks...looks like she's going to the shop. Consider this closed.
Peace
