Blew out a speaker
BlackXC90T6AWD
- Year and Model: 04 XC90
I blew out my passanger door speaker i need to know what can i replace it with does it have to be a volvo speaker or could i buy something from best buy???
fazool
- Year and Model: S60, 2007
- Been thanked: 7 times
It depends on which sound system you have but, generally speaking there is a 6.5" mid-range speaker low in the door panel and a 1" tweeter up in the door handle area.
I did it both ways. The Volvo speaker is typical overpriced OEM stuff. Its also easy enough to replace (lots of posts here on methods).
For my second project, I bought Sony xPlod series 6.5" component speakers and replaced both the tweeter and the lower door speaker. The sound is outstanding.
Don't just buy a normal replacement speakers. Those are 4ohm and the stock speakers are component speakers which run 8ohm each and in parallel give 4ohm impedance to the head unit.
Here are four options:
1) go to sonic electronix or crutchfield (or some similar) website and check their clearance section for a 6.5 component system thats an open box and missing some parts. Buy that and you will get just the 6.5" speaker part. Mount that (see prior posts about mounting techniques which are easy)
2) go to Walmart.com and buy a 6.5" sony xPlod component system (not a multi-way speaker - it MUST have separate tweeters) replace just the woofer part.
3) do the same but also replace the tweeter at the same time for a nicer balanced sound (see prior posts for tweeter mounting options)
4) do whatever you did on the other door so the sound is nice and balanced
My suggestion (based on lots of such experience) is to do #3 & #4. It will cost you $60 and about 3 hours of work for the first cautious time and your sound will be MUCH better.
2007 S60 2.5T AWD (Daily Driver)
2001 S60 2.4T (Daughter's Car)
2003 S80 2.9 (Son's Car)
1995 850 2.4 (Daughter's Car - sold off)
2005 S40 2.4i (Bought new - since sold)
1986 740GLE 2.3(First Volvo - sold off)
- 1248 Views
Last post by Ben850
- 1037 Views
Last post by mouseskowitz
- 589 Views
Last post by sclark0711
- 11 Replies
- 2528 Views
Last post by bob850
- 18 Replies
- 3817 Views
Last post by erikv11
