Possible explanation for this?
BlackJack
Year and Model: s70 1998
Post by BlackJack »
in 1st gear, move up to 2nd gear, clutch fully released fine, pressed accelerator to pick up speed, foot off accelerator and car then jumps back slightly?
edit: and i dont mean slowing down, more as if you actually pressed the brake
firestix
Year and Model: 1998
Post by firestix »
are you used to automatic transmissions... because this sounds like compression braking. If you revved up 2nd real high then let off the gas the engine and transmission will effectively brake for you.
BlackJack
Post by BlackJack »
I have been driving autos before this and this is my first manual so i take it thats?
msgtusmc
Year and Model: C70, 1998
Post by msgtusmc »
Standard transmissions operate via clutch paks, pressure plate & throw out bearing. I would check these for wear & adjustment. Inpection of drive shaft, universal joints and drive shaft/rear differential for play/wear might be needed.
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
That's normal. Lower gears will "brake" more. It's the same effect almost as dropping an automatic back down to 1st gear while driving around 20-30 mph - it will abruptly slow you down.
'98 S70 T5
2016 Chevy Cruze Premier
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Very normal in 1st and 2nd gears. Not so much in 3rd and not at all in 4th or 5th.
