Oil filter seal warning!
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
Changed fiance's Honda Civic's oil on Sunday. Monday she calls from work: oil light came on in last 4 minutes of her drive to work. (She didn't hear any strange noises.) My brain's Freak Out light comes on. :shock:
Turns out I didn't check the mounting surface of the oil filter coupling on the block (or the old oil filter) for the rubber seal ring. The old one was still on and the new filter went over it, and this was the source of oil leakage.
Most of the oil came out, but luckily the filter is high on the block or pan, so there was still oil in the system. No apparant engine damage, but we'll really know when the car is 100k miles old, or if it starts to burn oil.
Learn from my mistakes! Check for this ring! And watch out for drunk bicyclists (see my post from 4 days ago on this fiasco). :roll:
Also -> Amazon link
Volvord
Post by Volvord »
I hope bad luck does not come in 3's Matthew, your up to 2.
The oil "O" ring experience is quite normal, but once you have it happen you definitly check and wipe the oil filter mount from then on.
http://www.Volvord.com
1998 C70
1989 744TI with a 400HP Ford 302 / 5 speed
