tweaked idler pulley
boonmariachi
- Year and Model: 850 non turbo , 1996
so i've gotten everything fixed. then the belt started walking off the alternator pulley!!!
so many problems with this car......then i take a closer look and the idler pulley is tweaked!!! so how do i get this off, of course i can't find anything on it so please help me out!!!
- 2012-01-29 12.26.07.jpg (635.21 KiB) Viewed 1976 times
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
What does TWEEKED mean? It's not sitting straight? It should have a bolt on the front of it.
boonmariachi
tweeked means not sitting straight and aligned with alternator pulley as you can see in the picture, there's a cover on the middle of the pulley but can't seem to get it off!!
- rspi
Contact rspi..
IDK, maybe someone will help soon. I'll check my repair manual.
precopster
- Year and Model: Lots
- Been thanked: 128 times
Always thought that "tweaked" meant modified for more performance, sometimes by a backyarder. ie: I have a cool ride with a "tweaked" motor.
Guess I'll have to look out for that in future!!
- regent
- Has thanked: 2 times
- Been thanked: 12 times
Your idler pulley does look quite offset on the image. See attached file for idler positioning - hope this is your case; if you have a different engine please specify engine type (e.g. B5252FS) and I will post another procedure.
Cheers!
Cheers!
Aux Belt Arrangement 850.pdf- (94.13 KiB) Downloaded 286 times
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
- Has thanked: 17 times
- Been thanked: 35 times
I'm not sure if it's tweaked- there are grooves on the belt that should keep it on.
I'm wondering if the tensioner is worn out, not putting enough pressure on the belt?
It would be very hard to lift- you really can't lift it without a tool.
One of your pulleys is wrong, either the alternator or idler. I bought an alternator with a pulley that had a spacer on it that pulled it away from the other pulleys. Your picture looks exactly like mine did. I had to order a pulley from the dealer but you could find one in a junk yard. Hope this helps.
Rob
Rob
I see that bolt cover in the (great!) attachment. How does one remove that cover to get to the bolt? The pulley could be shot, with the center hole wallowed out, which would also explain its lop-sidedeness...but I doubt it...
- 2068 Views
Last post by precopster
- 1812 Views
Last post by Ben850
