Brake line bleeding
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
KEEman
Year and Model: V70 2003
Brake line bleeding
Post by KEEman »
My left rear clipper was hanging up. I decided to replace both rear calipers. Replacement went without a hitch. I did a Manuel blead until I got a stream of Brake fluid the first time with the engine off. My test drive revealed a spongy pedal. The next bleed I performed with the engine running again until I got a stream. Only difference this time was I saw no air in the fluid at the start of the process. Total "bled" fluid amount was about 1/4 pint. The brakes still have a spongy feel. Any suggestions?
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Best way is the old way
Have someone inside the car, open the bleeder valve, have them push the pedal to the floor, close bleeder, repeat.
Then go over to the other side and repeat
ctrobk
Post by ctrobk »
There are some other posts on this site that have said if the springs are not installed correctly, you will get a spongy feel to the brakes. One member even went and replaced the master cylinder only to find out the springs were not installed correctly.
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
If you do it the 'old way' make sure you limit the travel of the MC piston by placing a shim under the pedal. It should NEVER be allowed to move beyond its normal displacement position or else you risk damaging the seals. :!:
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
