Heat 1/2 working, cold air at face, hot at feet...
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
I believe I read about this somewhere but can't find it now. My '95 850 with ECC is blowing cool air in my face and hot on my feet. What causes this? Yesterday was the firts real cold day (23 degrees F) and it kinda sucked.
RDEJR
Year and Model: 850 GLT Wagon, 1996
Post by RDEJR »
Would you happen to know if all the dash vents are blowing cold air, or just the center ones?
Look to the left of your center dash vents at the dial for "Air Mix". Make sure that it is rolled to the up position, otherwise you will get cold air in while driving around even with the heat on.
Otherwise, it sounds like you've got a door or two that isn't working properly.
My T5 never chirps tires - it's a slow fat whale from a stoplight. - jblackburn
1996 850 GLT Wagon (Soon to be Turbo!) - Black and Mild
1995 850 Turbo Wagon - Sleeper 'goon.. never giggled so much...
rspi
Post by rspi »
I'll double check that mix vent dial. I never knew what that was for.
Today I felt less air flow and warm air. Maybe I closed that vent by accident.
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 93 times
Been thanked: 146 times
Post by BEJinFbk »
Per the 850 OM:
rspi
Post by rspi »
So, people actually read stuff in the owners manual :?
rspi
Post by rspi »
Yep, air mix is now closed and all air is warm.
I guess I need to count my blessings, 200,000 miles and only need a lower control arm. :)
RDEJR
Post by RDEJR »
Glad that worked for you.
