Turn signals stop working when I turn lights on
1998 S90.....My 4 way flashers and turn signals work fine until I turn on either the marker lighs or headlights. With the lights on the dash light for the right turn signal stays on continuously no matter where the turn signal is at.Any ideas?
Billc1015
- Year and Model: 1994 855 turbo
Sounds like you have a bad ground circuit for the lights. I would check all the grounding points on the body/frame to make sure they ate clean and tight and check the bulb sockets to make sure thay are not damaged.
I am here: http://tapatalk.com/map.php?ajxygu
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
I haven't seen one that bad before. Is the bulb holder allowing the bulb to move around?
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
Billc1015
That will happen with cheaper bulbs. The contacts are made out of softer metals and the heat of the bulb causes them to melt a bit.
I am here: http://tapatalk.com/map.php?in1gl3
- regent
- Has thanked: 2 times
- Been thanked: 12 times
I have found melted bulb solder due to local overheating as oxidized surfaces cause the contact resistance to increase.
Prevention: Use non-abrasive methods to clean the contacts (socket and bulb) and then coat lightly with "bulb grease"
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
- 618 Views
Last post by mjlsoprano
- 2017 Views
Last post by zupta82
