SRS Service Urgent ?
fazool
Year and Model: S60, 2007
Been thanked: 7 times
Post by fazool »
Hi all,
I was just completing a mod to wire a stereo input jack into my HU-613, piggybacking into the tape deck signal. That worked great (separate post to come).
But while doing that I turned the car on several times for testing etc without the CCM connected. Of course the windows and remote etc did not work.
Once I reconnected everything, everything worked perfectly but now when I started the car I got an SRS Service Urgent message.
I am thinking its related.
Thoughts and suggestions please.
2007 S60 2.5T AWD (Daily Driver)
2001 S60 2.4T (Daughter's Car)
2003 S80 2.9 (Son's Car)
1995 850 2.4 (Daughter's Car - sold off)
2005 S40 2.4i (Bought new - since sold)
1986 740GLE 2.3(First Volvo - sold off)
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
Did you disconnect/reconnect the battery 'by the book' or only removed fuses?
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
fazool
Post by fazool »
Bah forgot to disconnect anything in the middle of testing
regent
Post by regent »
Try first the old-school trick by disconnecting the battery and then re-connecting it after an hour or so, but first please read and follow the manual for each part of the excercise. :!:
If the above does not help, it may still be possible to read and clear the codes at Autozone (they usually say they are not allowed to reset anything, but try); if the codes are SRS-related (which apparently is the case) you may need a proprietary scan tool like a Scantech or VIDA DiCE environment.
Attached procedure (for "just in case")
Cheers :D
2005 S60 Battery.pdf
Battery Procedure P2
(60.36 KiB) Downloaded 807 times
2015 BMW 335i
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
That won't work and dealer only for a reset (don't waste your gas)
fazool
Post by fazool »
Bah! Clever $5 upgrade gonna cost me $110
jda2000
Year and Model: 04 V70 2.5T 01 V70T5
Post by jda2000 »
fazool wrote:Bah! Clever $5 upgrade gonna cost me $110
This is a good time to get your vida/dice setup for about $180 shipped from China.
Is a tool that will last a lifetime to care for your volvo, and by the way, it will turn off that pesky SRS light :lol:
fazool
Post by fazool »
ANy links or sources that you'd recommend ??
JRL
Post by JRL »
Google VIDA DICE
You will see several from China. Those are the ones to get, they work
thetazjagman
Year and Model: 96-850 & 01-V70
Post by thetazjagman »
I just had this happen to me when I disconnected the radio as I was replacing the mini light bulbs in the dash(replaced them with some blue, red & also some UV LED bulbs( from www.autolumination.com). I sent for a reset tool from FCP Groton, am expecting it any day now. Will repost once I receive it & use it to reset mine on an '01 V70. It list for $169.00 but I had a coupon code which brought it down to $143.00...I'll keep ya posted...
