http://www.odometergears.com/subpages/volvo.html
I've had more than a few users ask about fixing their stuck horns. If you're up to doing the job yourself -- which I have not done and would recommend caution because of the airbag located in the steering wheel -- that is the link to use to get the parts. Parts for both 850s and 70 series Volvos (and many others).
Stuck horn (!) and odometer fix parts online retailer
- Has thanked: 2662 times
- Been thanked: 1256 times
Donsweeneyny
- Year and Model:
Just ordered one after 1.5 years without a horn! My kid is learning to drive so I tried to repair it with tape, epoxy, glue, etc. All failed.matthew1 wrote:http://www.odometergears.com/subpages/volvo.html
'95 850 Turbo Wagon
Donsweeneyny
- Year and Model:
Parts came and I installed it in less than half an hour. Worth every penny. Instructions clear. Highly recommend.
[ Just ordered one after 1.5 years without a horn!
'95 850 Turbo Wagon
My $0.39 fix for a stuck horn -- ground a groove behind the contact button using my Dremel with a thin cutoff wheel, reinstalled the contact and secured it in the bracket with a size 00 O-ring. Insulates and holds it in place fine. Just ground away the plastic where the flange had broken off, about a 1/16th inch ring of rough plastic (fatigue fracture) just behind the button.
VCA
- Year and Model: 2008 S80 T6 AWD
- Been thanked: 5 times
Yes, because you're working with SRS wiring, you *must* disconnect the negative battery cable. Also, when you reconnect the battery, turn the ignition key to II and then reconnect the negative battery cable. Do not enter the car until the SRS light has extinguished or has remained on for more than 1 minute (meaning that it's set a code).vtguy84 wrote:For the ones who have fixed it, did you have to disconnect the battery? I'm having a hard time trying to loose the battery cable
2008 S80 T6 AWD
1999 S70 GLT
1999 S70 GLT
- Has thanked: 17 times
- Been thanked: 35 times
You know it's from the rear, right?
Are you using a torx bit in there?
- 1357 Views
Last post by tryingbe
- 638 Views
Last post by polskamafia mjl
