98 V70T5 blower not working
redt5
Year and Model: V70T5, 1998
Post by redt5 »
I have a new problem. The blower just stopped working. I checked the fuses but all seems good. Any ideas on what to check next?
Thanks in advance for the help!
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
Are the headlights and other electrical accessories working? If not, jiggle the ignition switch.
If they are, probably either the blower itself has failed or the blower resistor back. Both are located behind the glove compartment liner. You can try jumping the blower with 12V to see if it will work.
'98 S70 T5
2016 Chevy Cruze Premier
redt5
Post by redt5 »
Lights and all other electrical are working. I will follow your advice.
Thank You!
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
I have a blower motor if you need it. If it doesn't work in any setting it's likely the motor. Usually if the motor is good it will work in one of the speeds.
