P2 ECM-614 ECM-614B ECM-612 ECM-611 exhaust reset valve Topic is solved
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
dymetz62
Year and Model: XC70 2005
Post by dymetz62 »
Sooo; I had a check engine light come on.Went to a dealer;they gave me a code for an exhaust reset valve;code ECM-614B. They gave me a 425.00 estimate. I'v check here and on a Volvo parts site and can't find any such part or code.It's typed on the reciept so I know I'm putting in right. It's a 05 XC70 2.5 T. Any ideas? Thanx
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 78 times
Post by chrism »
They may be referring to the exhaust cam VVT solenoid - I believe it may be called a reset valve sometimes.
http://images.search.yahoo.com/images/v ... nRKh5Jgl0J
How's that for a link?
Some people warn against messing with it without a cam hold tool. I've never dealt with it so I can't say for sure.
dymetz62
Post by dymetz62 »
Thanx for the response;Ithought that was it.I don't know anything about a cam holding tool either.I'll just go till I can fix it!
jmlalley3
Year and Model: 2007 XC70
Been thanked: 2 times
Post by jmlalley3 »
I have a 2007 XC70 with 170K miles on it. Last week, I started getting intermittent and E614 error and then also E611, both exhaust and intake selenoid errors. I decided to replace the camshaft position sensor as a first step. While in the process of removing the camshaft position sensor, I discovered that the Camshaft Position Sensor Housing, Volvo 30650664, was cracked.
I replaced this and, since I had it, the camshaft position sensor, since I already had it. I have not had an error code since.
Has thanked: 1507 times
Been thanked: 3822 times
Added ECM codes to title fir search
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
jmlalley3 wrote: 06 Sep 2021, 12:02 I have a 2007 XC70 with 170K miles on it. Last week, I started getting intermittent and E614 error and then also E611, both exhaust and intake selenoid errors. I decided to replace the camshaft position sensor as a first step. While in the process of removing the camshaft position sensor, I discovered that the Camshaft Position Sensor Housing, Volvo 30650664, was cracked.
had similar problem after a cam seal job, turned out the cam sensor was slightly loose.
