Name this Hose - Volvo 760 (See Picture)
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
melizzuh
Year and Model: 1989 760
Post by melizzuh »
Hey guys I am sharing a picture with you of my car before I took it to the mechanic I had gotten it back and this hose is missing, I need to get it replaced, and find out where it goes, and whats connected to where it is supposed to go and whats connected there right now, because I cant find any openings on the motor where it could go? Please help out! Thanks guys!
By the way its an '89 volvo 760 2.3, w/ stock Garret TB03.
Where does this hook u p to the motor? Whats the name of this hose?
what hose.jpg (695.4 KiB) Viewed 522 times
Reason: Please -- no exclamation points in titles.
jimmy57
Been thanked: 320 times
Post by jimmy57 »
It goes under the intake manifold. Almost directly under the #3 runner. Hose will pass between #2 and #3 directly inline with throttle housing. There is a fitting that is shaped like a "Y" with a large fitting going down to crankcase breather box and a small nipple with a vacuum line and another large nipple the inner hose of the one highlighted goes on. There should be a roughly 1/2 inch inner hose inside the outer foamy rubber insulating hose from turbo inlet tube.
It is the crankcase venting hose.
melizzuh
Post by melizzuh »
Thank you! I got the manual on pdf, and found it yesterday, its next to the hose coming from the heat valve right? I couldnt tell before because the hose was cut and hidden up against the bottom of the intake manifold so I went to autozone and hooked it back up! still have 2 more cut hoeses for figure out, and one cut hose that plugged up with a bolt. :/
and a blue socket fuze thing, not sure what its called, but it isnt hooked up to anything, and its under the intake manifold, I found it loose and hanging out when I was looking for where that hose went, its one puzzle after another:/
melizzuh
Post by melizzuh »
My only thing though is it didnt relate to the image like I am seeing in the manual, the hose fit, and the outlet nipple thing was exactly the same as the one on the hose coming from the intercooler/turbo, but it didnt have another nipple or hose thing coming from it, it looks like there is something else supposed to be connected to it? What would that be? And why does mine not have it ?
