Coolant Smell in Cabin Heat on Vents Open only
washdup
- Year and Model: 1998 V70 T5m
- Has thanked: 1 time
First of all, I replaced the heater core about two years ago after getting a strong coolant odor and fogging windows. Ever since, there is still a coolant odor, but only when set to Heat, only when the dash vents are in the open position, and only for around 15 seconds before going away. I checked the connections at the firewall and they are dry and there is no coolant puddled or dripping anywhere in the cabin near the core.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Probably just residual crap in the ducting down there. Did you wipe the housing and stuff out when you installed the new one? If not, that's not too hard to do with it still in.
'98 S70 T5
2016 Chevy Cruze Premier
washdup
I don't remember specifically. There was not a lot of leakage out of the old unit, but it did look shot. Is the ducting you refer to located in the same area behind the dash?jblackburn wrote:Probably just residual crap in the ducting down there. Did you wipe the housing and stuff out when you installed the new one? If not, that's not too hard to do with it still in.
jblackburn
Yeah. That white enclosure thing around it.
'98 S70 T5
Hi, I'm having the same problem. I'm experiencing full pressure an no coolant loss. No leak residue or wetness but still have the smell when heat is turned on. I was wondering about your repair. How was a leak in the engine compartment causing a smell in the cabin? Just wanted to know before I start the heater core operation. How long should a heater core take to install? Thanks for the info:)
- 26 Replies
- 5487 Views
Last post by dejanaleksov
- 530 Views
- 12 Replies
- 822 Views
Last post by ericmci
- 1690 Views
Last post by mecheng
- 1509 Views
Last post by barcode
