2004 V70 w/ 145K miles. The climate control fan continues to operate with the ignition turned off. The only way to stop the fan is to pull the fuse momentarially. In additiion, when the vehicle is operating, there is no control of the fan speed using the variable position fan switch. The AC works fine. I'm thinking that there may be a relay problem, but that does not explain the fan speed switch not functioning.
Any thoughts or suggestions would be appreciated.
V70-Climate control fan continues to operate
DGM
- Year and Model: V70 2.4i 2005
- Been thanked: 3 times
The module is part of the blower assembly. Both have to come out.jsturt wrote:Thanks! Do you know if the fan control unit can be accessed without removing the fan assembly?
https://www.matthewsvolvosite.com/forums ... =9&t=21343
V70 2005 2.4i 195,000km, sold
S70 1998 T5 355,000km, sold
960 1994 80,000km, sold
760 1990 Turbo 265,000km, sold
- 12 Replies
- 3134 Views
Last post by Kulu
- 1931 Views
Last post by mrbrian200
- 791 Views
Last post by ThaddeusTheBold
- 406 Views
Last post by mmpeterson1850
- 1781 Views
Last post by oragex
