Hi,
New to this board - I will be "inheriting" my moms 2006 S60 Volvo soon. It is in great shape with only 32,000 miles on it. However, there is an ongoing issue that, so far, the Volvo dealer can't figure out. It isn't all the time but the last time I drove it there was a "clunking" noise that sounded like it was coming from the front end when I turned the steering wheel hard right (I think it was right but can't be sure). It is a noticeable sound with others outside the car mentioning it. This car has been very well cared for and only goes to the local Volvo dealer. It seems they can't replicate it or figure out what it might be. I'm concerned that it could be something with the axle that could effect steering and be potentially dangerous.
Tomorrow my mother is taking it to the Volvo dealer for a final inspection and I wish I had found this board earlier as I realize I might not get any responses this late. If anyone has ideas that she can share with the mechanics please let me know - I would appreciate it!
Thank you
Barri
Clunking noise on hard turns
- cmblackburn
- Year and Model: 1998 S70 T5M
- Has thanked: 1 time
- Been thanked: 7 times
Could possibly be the cv axle. Check the boots for tears. Also check the steering stops.
1994 855 Turbo, 243k "Honey Badger"
1998 S70 T5M, 287k "The Blue Turd"
2004 S40 2.4i, 197k "Cosmo"
2005 XC90 2.5T AWD, 207k "Apollo 13"
2011 VW Jetta SportWagen TDI 6MT, 93k "Zoe"
vjaneczko
- Year and Model: 2006 S60R
Does the noise come form the right when you turn it to the right?
1997 855 GLT - R.I.P.
2006 S60R - For ME!
2006 S60R - For ME!
Find some place you can make hard rt and/or lt turns and make circles if it keeps popping it likely low grease / ripped boot on CV shaft. If not check rack on steering being tight to frame if not that lift hood bounce front end check top rubber mounts for being worn/torn finally links at ends of front sway bar are known to pop and/or break due to grease coming out of sealed pivots. (Good sway bar replacement links come with grease fittings on them) gl
badnewsguy
- Year and Model: 2000 c70
I had the same sound thought it was the cv joints come to find it was the struts were out and also when replacing them i saw the ball joints had taken the last the could before it was going to be a on the freeway with only 3 wheels.
have it checked soon, if it is ball joints very bad stuff can happen
- 625 Views
Last post by SuperHerman
- 1538 Views
- 2269 Views
Last post by RockpileUK
- 980 Views
Last post by Cees Klumper
- 13 Replies
- 3219 Views
Last post by Clockboy
