Rubbing/grinding noise when turning
Donniegood
- Year and Model: 2000 v70
I have a 2000 Volvo v70 no turbo with everything stock I recently purchased. It has been well maintained with records but after 2 100 mile trips I have developed a grinding somewhere in the front end when turning. I have not had a chance to check get under it (just got home from honeymoon) but I do know he had some caliper work done within the last year. Anything specific I should look for? Not sure if suspension is original off the line haven't had time to dig into the records he left with me
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Turning at full lock as in parking lots? The wheels rub the fender liners on many Volvos. Old shocks, bad alignments, wrongly-sized tires, or broken steering stops on control arms could be to blame.
Or just turning to go around corners, etc?
In that case, it could be something like a bad outer CV joint or bad wheel bearing.
'98 S70 T5
2016 Chevy Cruze Premier
Donniegood
Not full turn just like into driveway probably half turn. I am hoping to get under it this week to see if there's anything I can see. Any easy way to tell cv or bearing I am by no means a mechanic but I know my way around a car for the most part
jblackburn
A bad CV joint can usually be traced back to popping noises when turning and an leaking or split boot on the axle. This will be readily visible just taking a look at it - just park the car with the wheels turned fully right or left and have a look at the boots on the axles.
'98 S70 T5
Donniegood
Ok I will check that out and report back it is definitely a grind at first I though something was dragging on the road but it's not
- 22 Replies
- 3294 Views
Last post by smacknab
- 12 Replies
- 2050 Views
Last post by PapaHepcat
- 842 Views
Last post by JRev
- 2567 Views
Last post by benpineapple
- 14 Replies
- 792 Views
Last post by rolsen11
