2004 v70 Rear wiper 'freezing'
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
ianners
Year and Model: v70 d5 2004
Post by ianners »
My rear wiper 'froze' at the '10 o'clock' angle (for the second time) this week. Last time it restarted itself a week later (!)- this time I moved it on manually this morning with the wiper switched on, and after a couple of degrees turning it completed the cycle by itself but then remained in the park position even though switched on.
Any suggestions?
Been a Volvo owner (two 740 estates to 200K miles pre this car) since '85. Love the power and economy of this one, tho upgrade to the next model looms with the approach of 200k again. (Or should I get a low mileage 2007 D5 this shape?)
Thanks all,
Ianners
jimmy57
Been thanked: 320 times
Post by jimmy57 »
Have you tried opening the tailgate to see if wiper motor started? If it is the harness wires to tailgate broken often gently raising tgate will make them work. If it is bad motor then banging on tgate will often make it work again temporarily.
wz-dc
Post by wz-dc »
The harness through the hinges easily could be the problem. My rear wiper quit working last week, I found the problem to be broken wires at the left hinge (4 wires broken).
For quick diagnosis you could try squirting WD-40 around the shaft to see if corrosion and binding up is the problem.
DGM
Year and Model: V70 2.4i 2005
Been thanked: 3 times
Post by DGM »
If you have broken wires in the left hinge this tread will help.
https://www.matthewsvolvosite.com/forums ... =9&t=35351
and the following to understand the mechanism.
https://www.matthewsvolvosite.com/forums ... =9&t=42226
V70 2005 2.4i 195,000km, sold
S70 1998 T5 355,000km, sold
960 1994 80,000km, sold
760 1990 Turbo 265,000km, sold
doleynik
Year and Model: 2001
Post by doleynik »
If you diagnose the problem I'd love to hear the solution. My rear wiper 2001 V70 T5 is doing much the same. The problem started when I lost a ball joint on the passenger side, the wiper came on then began to fail shortly afterward. At the time I thought it was related to the damage caused by the tire hitting the inside of the fender well.
ianners
Post by ianners »
Thanks all. I tried your suggestion about raising the tailgate/ wiggling the LHS wires behind the hinge cover, but no joy. I realise I misled you by saying the wiper remained in 'Park' - actually it sticks at the extreme left position ('9 o'clock') but can be induced to restart by moving it past '10 o'clock'. It will park on the right side if switched off, but at '9-10 o'clock' if left on. It therefore looks as if I have an issue on the wiper motor at that portion of the cycle and will have to uncover that mechanism. Comments?
DGM
Post by DGM »
ianners wrote:Thanks all. I tried your suggestion about raising the tailgate/ wiggling the LHS wires behind the hinge cover, but no joy. I realise I misled you by saying the wiper remained in 'Park' - actually it sticks at the extreme left position ('9 o'clock') but can be induced to restart by moving it past '10 o'clock'. It will park on the right side if switched off, but at '9-10 o'clock' if left on. It therefore looks as if I have an issue on the wiper motor at that portion of the cycle and will have to uncover that mechanism. Comments?
The gear in the casing can be worn out as shown in this picture.
Gear worn out rear wiper V70.jpg (100.5 KiB) Viewed 1809 times
Open the case to assess its state.
The following link is showing many pictures of the inside (near the end). This is from Club Volvo Quebec and I guest you can capture the essential.
http://forums.clubvolvoquebec.com/showt ... hp?t=16869
ianners
Post by ianners »
Thanks DGM - that sounds like it. Will check.
