Hello everyone...
So I was just starting a rear suspension job on my 850 sedan by following these instructions (Thank you so much polskamafia btw):
https://www.matthewsvolvosite.com/forums ... =1&t=31410
And guess what? A bolt broke.
So what could I attempt before bringing it to a mechanic? Or is it such a PITA that I should just pay the mechanic to do it? Or... is it such a HUGE PITA that I shouldn't bring it there, otherwise it'll cost me several hours of labour just for one bolt?
Thanks,
-Jack
Broken Bolt - Rear Suspension
Jack_Inaboxx
- Year and Model: 1996 850 GLT
- MoVolvos
- Has thanked: 310 times
- Been thanked: 524 times
If you are referring to the Lower Shock Mounting Bolt this may help guide your decision on what to do?
https://www.matthewsvolvosite.com/forums ... 5&start=14
Jack_Inaboxx
No, it is one of the bolts of the shock mount bolts, like shown here:
https://www.matthewsvolvosite.com/forums ... d=5649&t=1
- MoVolvos
That area is fairly accessible so you have room to work. Take a look at this video to see if it helps as he mentions several ways and some of the difficulties. Try some other videos from the link to see if it gives you enough info to decide whether you want to tackle it yourself.Jack_Inaboxx wrote:No, it is one of the bolts of the shock mount bolts, like shown here:
- Been thanked: 468 times
Try this:
DIY: 1998 Volvo V70 Rear Shock Absorber (Bilstein TC) & Shock Mount
https://www.matthewsvolvosite.com/forums ... =1&t=28318
