Brake Light Malfunction
1996 - 2004 S40
1996 - 2004 V40
zulu-v40
Year and Model: 2003 V40
Post by zulu-v40 »
Symptoms:
Brake lights turn on when pedal is depressed and car is off.
Brake lights don't turn on when pedal is depressed and car is on.
Cruise control will not engage.
Fuses are not blown.
Bulb failure indicator light is lit on dash.
I replaced the brake light switch, which did not solve the problem. Any ideas? I am stumped.
2003 V40 T4, silicone vacuum hoses, K&N air filter, iPd Boost Gauge, iPd HD TCV, PowerSlot Rotors
zulu-v40
Post by zulu-v40 »
When I'm underneath the steering wheel and depressing the brake pedal, I can hear something switching on and off underneath the radio near the gear shifter. So, it sounds like the brake pedal switch is functioning, but I still can't figure out why the brake lights do not function when the car is running.
jimmy57
Been thanked: 320 times
Post by jimmy57 »
the click is your shifter locking mechanism, the thing that keeps you from moving gear lever from Park until brake is depressed.
In the dark have someone start the car and watch the tail lights closely and then apply the brake. I'm suspecting a bad ground and the taillights being on is killing the back feed grounding the tail light bulbs provide when not powered.
Does the upper brake light work at all?
zulu-v40
Post by zulu-v40 »
The upper brake lights do work, but only when the car isn't running. I've had someone watch. The bottom brake lights stay on all the time when the car is running (even when switching out of daytime running lights mode). The upper lights do not light up at all when the car is running.
zulu-v40
Post by zulu-v40 »
When the car is off, if I depress the brake pedal, both window switches light up... Just discovered this in the dark tonight. When held for a few seconds, not only do the window switches light up, the stereo turns on.
zulu-v40
Post by zulu-v40 »
It would appear I've located the problem. I tore apart the tailgate looking for a rear electronic module, which I'm not sure even exists, and in doing so discovered the wiring harness for the tail lights was touching the nut located directly above in the picture. I'm not sure if that nut is grounded, or if that even matters, but clearly the harness did not fair very well...
Here is a close up of the mess:
So, my big question is what do I do next? Can I just splice new wiring in with crimp connectors and call it good?
zulu-v40
Post by zulu-v40 »
I believe this is the harness and part number.
http://tinyurl.com/83tfyy5
Upon further inspection, there appear to be 16 wires, two of which are of a thicker gauge (red and black in color). I think it would be more cost efficient to do the wiring myself. Thoughts anyone?
