Greetings all,
I am an emergency responder in NJ, and I would like to install some emergency lights on the top of the windshield.
Can someone tell me how to remove the panel in front middle of the ceiling (the one who has the sun roof button, reading lights, etc..) without breaking it ? I thin it is the only thing that holds the ceiling to the roof...
I am trying to access the part that goes from the top of the windshield to the sun visors screws
Thanks !
How to remove the ceiling ?
Removing a Headliner — Volvo XC90
JDS60R
- Been thanked: 3 times
Here you go !!!
2008 XC90 interior roof console remove.pdf- (302.71 KiB) Downloaded 1926 times
Retired
simon templar
- Year and Model: XC90, 2008
HI !
Thanks a ton. My issue is actually with what they call the ROOF MODULE in your document.
Would you have anything that explain how to remove it without breaking it ?
When I had a jeep, I was able to buy the service manual and do a lot of mods myself.
Where can I buy the service manual for Volvo ? The only thing I found is this online subscription crap.
Thanks !
Thanks !
JDS60R
Roof module
Instructions - Your dealer uses a system called VIDA. I have heard you can buy one online.
08 xc90 roof module.pdf- (109.71 KiB) Downloaded 1097 times
Retired
simon templar
I will look for the module, thank you...
Now, can you share the "interior lightning" module ?
The one you just shared refers to it...
Thanks a ton
Thanks a ton
simon templar
HI ,
I meant this module: Bulb interior lighting, replacing .
I believe it is the complement of "Interior Lighting, replacing.
Thanks
Thanks
simon templar
Hey,
I'm searching for VIDA on line, which brought me to volvotechinfo.com
Where do you buy the DVD or Installation file, that will make this available on your computer, without needing to be online connected to volvotech system ?
Thanks
Thanks
JDS60R
The Bulb module is the rearmost light. I imagined you just dropping the front of the headliner so you can run wires.
Here is the bulb module
Bulb.pdf- (61.16 KiB) Downloaded 853 times
Retired
- 1256 Views
Last post by Webpirate
- 988 Views
Last post by CIK7
- 7210 Views
Last post by SuperHerman
- 1295 Views
Last post by skloon
- 1147 Views
Last post by JimBee
