740 turbo power/fuel issue
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
travis873o
Year and Model: 1990 740T
Post by travis873o »
So, here's where i'm at:
-I've replaced the intank pump/sock filter. Verfied that it is working.
-Replaced fuel filter
-checked the fuel pressure regulator and it is in working order.
-I can hear my main pump running.
Symptoms:
No power past half throttle almost like a fuel cut but i'm only pushing 9lbs max.
I only have no power after the vehicle is warmed up and is even worse on hot days.
Any thoughts? I'm pretty sure this is a fuel issue but could it be a vaccum issue?
Thanks
itguy1010
Year and Model: 740 B230F 1987
Post by itguy1010 »
Hi Travis,
Have you tried any of this:
http://www.volvoclub.org.uk/faq/EngineO ... sticCodesi
Your '90' 740T diagnostic codes may help rule some things out. Does the problem occur at a certain RPM every time? See what kind of codes you get and post your findings.
Eric
"There was a time when being crazy meant something... nowadays, everybody's crazy."
travis873o
My check engine light does not come on though. Could I still have a code but no light? The light does work, it comes on for the gauge light test when i start the car
travis873o
bump
