this car has wrecked me
i got a 2002 v70 cheap. apart from a turbo problem that led to overheating ,all was fine. changed the turbo and it worked fine. then one day, it just stopped revving. changed MAP sensor, TBPS, coils, plugs,injector etc. strange thing is only P0443 comes out of the scan. starts up when cold and sometimes revvs for less than 3mins. but once car is hot, doesnt even startup. any ideas?
RaymanSean
- Year and Model: V70 XC, 2001
It sounds like you replace part$ hopping that they will fix our problem. There is nothing wrong with replacing a faulty part with a operational part. The hard part is determining what part is faulty. Turbo leading to overheating, please explain....
Have you done a compression test? How about check the exhaust pressure before and after the cat? Also check the exhaust pressure before the Turbo, if you can.
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
P0443 indicates a problem with the evap control purge valve, possibly sticking open or sticking shut. What happens if you run the engine for a couple minutes until it starts to act up, then open the gas cap? Is there a rush of air either into or out of the tank?
- 2949 Views
Last post by misha
- 573 Views
Last post by dwhite66
- 984 Views
- 15 Replies
- 12197 Views
Last post by oragex
- 1591 Views
Last post by wizechatmgr
