Aftermarket vs Volvo Catalytic Converter for V70
Volvogurl
Year and Model: V70 1998
Post by Volvogurl »
Hi, My '98 V70 (150,000 miles) just failed the California smog test (at 15 mph only--high NOX, passed at 25 mph) and my longtime Volvo mechanic ran the proper test (don't remember what it's called but OEM is part of the name) and he said the car needs a new catalytic converter.
The part from Volvo costs $1,100 plus about $150 for installation.
The Volvo mechanic, who has worked on my car for more than 10 years, agreed that the part is expensive and suggested that I take it to an independent muffler shop to get a quote for an after-market cat. I went to a place he mentioned that has a positive YELP rating and the owner told me that he can install a cat made by Carsound for $335 plus $100 for labor. It's guaranteed for 50,000 miles. I checked online and the part is legal in California.
When I went back to the Volvo mechanic, he was unable to provide clear advice as to which way to go. He said the aftermarket parts usually are not built to last whereas the Volvo part should last at least 10 years. I know he's not trying to just get my business because he actually suggested that I talk to the independent shop in the first place.
My question is, does anyone in California have experience with Carsound catalytic converters and do they work on 98 Volvo V70s? Do they last? The impression I'm getting is that aftermarket cats only last a couple of years. This is my only car and I want it to keep driving it for several more years.
I'm not a mechanic. I just own a Volvo.
Thanks,
Lisa
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
Hi Lisa,
If you are near Independent Volvo pick up 7 quarts of Swepco 306 15W40 from Antonio and a bottle of Swepco 503. Drive it a couple of hundred miles and retest. This should take care of it. A friend's older Benz sat for four years in his garage as it did not pass the CA Smog and with those two added he passed. The price is for reference as Pelican charges for shipping Independent is pick up.
http://www.yelp.com/biz/independent-vol ... lnut-creek
http://www.pelicanparts.com/catalog/sho ... detail.htm
This worked for a forum member who tried it if the Catalyst is indeed somewhat out of spec. Yours should be OK still as it has not thrown any codes
rmmagow
Been thanked: 2 times
Post by rmmagow »
Try what BKM is suggesting or you can go to a car parts place and talk to them about Converter cleaner that you add to the gas. Drive the car with two tanks of treated gas, drive at good high speeds for a while. My old Mazda failed emissions for the same reason and passed after doing this kind of treatment. I had exactly that same symptoms, high NOX at low speeds. Because my Mazda is so old, they need to "sniff" the exhaust for the emissions test. After treatment it passed easily. The high speed helps get the converter nice and hot to help burn off buildup. I used some additive that said "guaranteed to pass", could have been a Lucas product. About 11 bucks a can I think.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
Year and Model: 2004 V70 2.5T
Been thanked: 472 times
Post by cn90 »
Many years ago, I used "DEC" brand on my BMW. "DEC" is a very good brand.
However, I have heard Bosal good too:
http://www.eeuroparts.com/Parts/PartDet ... amNumber=6
If you plan to keep the car for another 5-8 years, I suggest that in order to save you repeated labor costs:
1. Consider changing the Exhaust Manifold. My Exhaust Manifold went out at the Flex Pipe @110K miles.
For this part, I used Volvo genuine ($300 or so) and Volvo gasket.
2. Also the Exhaust Manifold mates into the Catalytic.
Just make sure you have the 4-bolt type.
At this area use also Volvo Gasket even if you use Bosal Catalytic.
If your car has never had a welding job there, your mechanic can install these for you as from factory, all these parts were put together by nuts/bolts, no welding.
3. At that mileage, the muffler may go any time, but this part can wait.
The KEY thing is: whatever aftermarket part (such as catalytic) you use, when it comes to gasket, use Volvo gaskets only!
The Exhaust Manifold DIY is below:
https://www.matthewsvolvosite.com/forums ... hp?t=40032
j_cd
Year and Model: 1998 S70 GLT
Post by j_cd »
Not to be a smarty pants, but the OP is in California and the Eeuroparts cat linked to above is not legal for sale in California.
This is something I've been wondering about lately as well, since I I hydro'd cylinder 1 and my cat may be weakened from un-burnt fuel. I don't think any of the aftermarket Volvo parts houses ship catalytic converters to California. And since none of them are based here, we may be stuck with the dealer or scrap yards.
Post by cn90 »
j_cd wrote:...the Eeuroparts cat linked to above is not legal for sale in California...
Thanks for pointing that out.
Smart California politicians at work LOL.
This ebay seller in L.A. sells DEC Cat for $478 incl. shipping.
However, if one lives is L.A., one can stop by this store and pick it up and perhaps save some $70 for shipping.
http://www.ebay.com/itm/DEC-VO93524-Dir ... 5298wt_959
j_cd
Post by j_cd »
Right arm, I was looking at a DEC cat on ebay just now as a matter of fact. Good call.
rmmagow
Post by rmmagow »
j_cd
Post by j_cd »
I was going to mention Magnaflow... saw some Cal legal ones at summit racing, but when I checked their website just now it was frustrating. If I ever do a full turbo back exhaust, maybe I'll get a Magnaflow cat and have a local shop build a custom mandrel bent 2.5" downpipe for it.
Ah, I see the link you've provided has the whole assembly, California legal for around $750. Pretty sweet.
j_cd
Post by j_cd »
Not to confuse the situation with overly technical info, but on those Magnaflow cats you'll notice the following quote:
Direct fit catalytic converter legal for sale in California under Executive Order (EO) number D-193-67. Before purchasing this product, please check the Executive Order at http://www.arb.ca.gov to verify whether this product is allowed for installation on your specific vehicle application.
This is the page you want.
https://ssl.arb.ca.gov/PartsSearchTool/CatalystSearchTool.aspx
Enter your year, make, model and engine size. The search will return a list of PDF documents. These are the executive orders, which are exemptions specific to each manufacturer of CARB approved aftermarket catalytic converters. The Magnaflows are listed under "Car Sound Exhaust System, Inc". For example, the number 446603 is listed on one of these pdf documents, and it's also in this ebay ad for a complete catalytic converter that fits my car.
www.ebay.com/itm/446603-1998-VOLVO-C70-2-3L-Magnaflow-Cali-Catalytic-Converter-/280900015473?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1998%7CMake%3AVolvo%7CModel%3AS70&hash=item4166f21571&vxp=mtr#ht_6003wt_947
Walker is also listed, they're made in Michigan. I don't see DEC, but they must be under one of these executive orders. If you download or view the executive orders, scroll way down to Volvo, and there you'll find your year/model and which part is approved for it.
I hope that makes some sense. :mrgreen: Only in California. :twisted:
