1999 V70 overheating
roberius
Year and Model: 1999 V70
Post by roberius »
I have a problem. My 1999 V70 is overheating after about twenty minutes. I replaced the thermostat and checked the sensor. That fan does come on.
Any suggestions?
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Do you have coolant in the motor/resivior? If so, you likely have a bad water pump. The perpeller may have come off the pump.
loub
Year and Model: 94,95,96 850,98S70
Post by loub »
In regards to your photo of the water pump with the impeller off; what did that sound like,rspi?
madspeed50
Year and Model: 1998 S70 T5m
Post by madspeed50 »
wp leaky at the seep hole?
Yep, sent from my rooted, rommed Galaxy Nexus....
roberius
Post by roberius »
Water in the reservoir. The water pump was replaced about three years ago.
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Water or correct mixture coolant in the reservoir? In warm conditions on an old radiator it can mean the difference between boiling and staying cool. By the way if fan is coming on at correct temp of 105degC this is already 5 degrees past boiling point.
Sent from my GT-I9100T using Tapatalk 2
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
roberius wrote:I have a problem. My 1999 V70 is overheating after about twenty minutes. I replaced the thermostat and checked the sensor. That fan does come on.
Any suggestions?
Can you give any information about the car prior to the overheating!
roberius
Post by roberius »
I have a 50/50 mixture.
No weeping from the water pump and no leaks.
YOu can drive it around for about 20 minutes and then the temperature go up.
Checked the coolant temp sensor, it is fine.
Replaced thermostat ( i thougfht this was it)
roberius
Post by roberius »
Also, reservoir remains full.
rspi
Post by rspi »
loub wrote:In regards to your photo of the water pump with the impeller off; what did that sound like,rspi?
Couldn't hear a thing. Just tried to overheat if driven normally. I drove the car home 20 miles without it overheating. No hard acceleration and kept it around 45 mph which seemed to be the best speed to keep the temperature under 230° F.
