B20 engine self repair
Heres a poser for ya. Yesterday while my 1800es was at idle there was a loud mettalic "ping" from under the hood, and the engine started clattering and running as if it had swallowed a valve. I removed the valve cover to look for the guilty part, but they were all in place. Afterward I could only get the engine restated by spraying a little ether into each cylinder. Here's the dillema: now, without any additional repair or adjustment from me it starts and run's like its never had a bad day in it's life. Any insight to this "Christine" like behavior would be greatly appreciated.
The good Major
rmmagow
- Year and Model: V70 1998
- Been thanked: 2 times
I'd check the ignition components and the air cleaner setup. I don't know this car or engine but is it possible for something o come off the air cleaner assembly and get sucked through? Small washer or some such? Ignition, rotor or cap problem, cracks etc?
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
If the car is rarely run or if it was run briefly the time before this event, the valve stem(s) may have rusted a bit and it had a sticking valve not closing fully. After it ran a bit it freed up and the oiling from rocker arms got it lubed and it's OK.
JDS60R
- Been thanked: 3 times
I have also seem the "barely stuck valve" issue as well as the front crank bearing shell being spun out. I have only seen the bearing spin once vs the valve sticking multiple times.
Retired
Thanks for the input guy's. The sticking valve idea would be likely if the car sat a lot, but it's my daily driver. She get's her oil changed and a new Mann oil filter every 3k. As far as the ring's breaking up ( I had a Dauphine that did the same thing) the engine was rebuilt 70k miles ago with new alloy pistons and molly ring's. I'm so frustrated with this "tractor" motor that I'm about to yank it out and put a V6 Chevy in it's place. Someone stop me before I do.
The good Major
