turbo boost guage
- Has thanked: 2865 times
- Been thanked: 1332 times
There is a vacuum tree on the intake manifold that has available/capped ports. Then run the line through the factory firewall tunnel, it comes out next to the brake in the footwell.
vjaneczko
- Year and Model: 2006 S60R
- Been thanked: 7 times
Your cluster should already have a turbo gauge, so you can daisy-chain your new gauge off of that.
1997 855 GLT - R.I.P.
2006 S60R - For ME!
2006 S60R - For ME!
D'oh! Vince is correct, there's already a vac line up there. Thanks Vince!
vjaneczko
The best turbo is usually the one that came form the factory unless you're looking at replacing an LTP with a HPT, so the first question is; do you want to replace it with something bigger? If so, how big do you want to go and what is your mod budget?
Depending on how big you want to go, you'll also have to upgrade a few other bits under the hood; ECU tune (for starters), exhaust & intake pipes & manifolds, injectors, fuel pump, etc. Then you'd probably also want to upgrade the brakes to handle the new power, and probaby deal with the suspension to make sure all that power will stick to the ground.
Might also want to spend some time searching over at Swedespeed.com - there's a ton of tuners over there that would be happy to suggest the biggest, baddest thing you could strap on.
2006 S60R - For ME!
2006 S60R - For ME!
- 21 Replies
- 5664 Views
Last post by j-dawg
- 11 Replies
- 1995 Views
Last post by erikv11
- 1730 Views
Last post by ajr91
- 365 Views
Last post by shaker_chi
- 791 Views
Last post by 93Regina
