I'm in the middle of removing the transmission on my 03 S80 and everything was going somewhat okay until I reached the part where I have to remove the driver side (left side) drive shaft. I tried pulling the shaft at the CV joint and using a screwdriver to pry the shaft out, at the point where the driveshaft enters the transmission, but both methods failed to work.
Well I went to Home Depot and picked up an angle bar for less than 10 bucks and pryed the drive shaft out. Now lowering the sub frame
