Demister switch stuck
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
anthonyhall
Year and Model: Volvo 740GL 1985
Post by anthonyhall »
The dash rear window demister switch on my Volvo 740GL (1985) has got stuck in the ON position, and the demister is still working. Do I need to change the control relay switch? If so, where do I find the relay to replace it?
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Attached is a diagram of the fuse/relay board for the '85 740. This is behind the front ashtray.
740 '85 Relay board.pdf
(204.55 KiB) Downloaded 95 times
However, if the switch is stuck replacing the relay will not solve the problem. You need to get the switch working or replace it.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
