I suspect I have a bad PCV due to the amount of oil leaking from various places, including my distributor. Could this cause an engine misfire? I get ODBII codes for "multiple engine misfire". Replacing the PCV seems a huge hassle since it's located under the manifold. I know it needs to be done but I'm wondering if replacing the PCV will cure my misfire problem. I replace the distributor cap and rotor a couple weeks ago and it still misfires. The old cap did have oil build-up on the contacts. I've also replaced the fuel filter and cleaned the MAF Sensor and tried a couple tank fulls of Premium gas. Still misfires.
George
1998 S70 non-turbo
135k miles
Could bad PCV system cause engine misfire?
- Been thanked: 504 times
Step 1: Overhaul the PCV:
https://www.matthewsvolvosite.com/forums ... hp?t=53448
Step 2: Replace Rear cam seals (SKF 11809 $10 at local Napa store):
https://www.matthewsvolvosite.com/forums ... hp?t=50752
Step 3, clean or replace cap/rotor.
Maybe time for new Bougicord too ($55).
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Yeah, an oil-coated cam sensor or distributor could do that.
'98 S70 T5
2016 Chevy Cruze Premier
- 1031 Views
- 628 Views
Last post by reltor
- 742 Views
Last post by magna224
- 163 Views
- 26 Replies
- 4318 Views
Last post by Sommerfeldt
