s80 tiptronic gearbox Topic is solved
Everything on the Volvo S80. Sometimes called an "executive car", the S80 was Volvo's top-of-the-line passenger car. P2 platform.
mikemmb
Post by mikemmb »
I would like to try to make a paddleshift.
Looking at the gearshift, it has rod linkage and what looks like microswitches.
Does anyone know if the manual shift is controlled from the switches?
If so it will be easy!
Mike
Guest
Post by Guest »
mikemmb wrote:I would like to try to make a paddleshift.
Mike
when i use the geartronic; as it autodownshifts at stops, you can feel something clicking in the shifter; so i assume you're problably correct.
