Pioneer’s AppRadio 2 in a Volvo
This topic is in the MVS Volvo Repair Database » Pioneer AppRadio 2 Install & Review
vjaneczko
Year and Model: 2006 S60R
Been thanked: 7 times
Post by vjaneczko »
I’ve had Pioneer’s AppRadio 2 in my S60R for a while and I was asked for my opinion so I thought I’d make a post and share it with everyone. My first thought about this unit was that it would be a second screen for my HTC Evo 3d from Sprint, but it’s a long way off of that wish.
I followed a post here and on SwedeSpeed for the install so I won't discuss the installation process but feel free to ping me with questions.
Almost done with the install - yes, those are dirty fingerprints on the screen.
The AR is a touch screen AM/FM radio with one cable that connects your iPod device and another cable that connects certain Android phones. That’s right, just a radio. Not even a CD player (ungh, how 1997!) The premise is that all of the functionality is in your connected device. Also note I said ‘certain phones’. You need to make sure your phone has been tested & certified by Pioneer. It requires an MHL or HDMI connection as well as a Bluetooth connection and a few apps installed. Since I don’t have an iPod, I’ll focus on my Evo 3d. I should note that my daughters do have an iPod plugged into the unit but I never use it.
Installation is pretty easy as it’s a standard double-DIN headunit. From Matthews Amazon link above (of course!), I picked-up the radio, a wiring harness, antenna adapter and a double-DIN mount. A note about the mount; I wanted to keep the cubby but couldn’t find an aftermarket solution and didn’t see myself spending $85 bucks for the Volvo bracket. Upon pulling out the factory unit, it appears that the cubbie is really attached to the radio bracket and not the faceplate itself so all I have to do is cut a hole to match the cubby and I’m all set – how hard can that be?! I haven’t done it yet but I figure I’ll get around to it this summer.
Since I decided to keep the Volvo amp & speakers, I picked up an adapter cable that goes from the Volvo DIN plug to two pair of RCA plugs.
I also picked-up a rearview backup camera, but haven’t installed it yet. I need to figure out the best place to mount it and I’ve not spent the time on that task.
Another item I purchased is the Pioneer HML adapter kit which, now that I know what it is, is waaay too expensive. If I had known what it was, I’d have bought a few items from Amazon and saved a bundle. More on that later.
Shortly after finishing the install, I decided to get an anti-glare film to help with the flat screen. It will also help if the windows are tinted to reduce the amount of glare – even with the film, there’s some glare to deal with.
Installation was straight forward. If you’re not familiar with radio installation, it can be frustrating working in a cramped space but then, as a Volvo owner you must be used to it by now. The only difference is that instead of getting greasy and cutting your fingers on sharp metal, you get sweaty and cut your fingers on sharp metal. There’s a butt-load of cables to deal with; RCA jacks for the amp or wires running to the speakers, Android cable, iPod cable, GPS antenna, microphone wire, backup camera wire, steering wheel wire, light dimmer wire, radio antenna, handbrake wire, reverse wire and of course the power wires.
Wires Everywhere
Wires Everywhere
A Dremel made quick work of the bits to be removed from the back of the Volvo bracket
I have not gotten the steering wheel controls or light dimmer connected yet. From what I've found, the only steering wheel interface is like 200 bucks and I gave up looking for a light dimmer adapter. I know that's because of the Volvo CanBUS system and not the fault of the radio, but it still adds to the frustration.
I also picked up the PAC TR-7 universal trigger output module which replaces the e-brake wire connection. The reason for this connection is that the unit will not run most apps unless the handbrake is engaged. So you have to wire the AR to the handbrake and engage it twice (yeah, it’s smart enough to count to two) before the AR believes you to be stationary. Now I’m not one to watch movies when I drive, but the idea is that using this module allows me to use the apps I want to use instead of the limited apps from Pioneer. I must admit I didn’t program it properly so instead of waiting a few seconds, I have to wait a few minutes. One day I’ll correct my mistake.
For the reverse camera to work, Pioneer says you have to wire the headunit to the reverse gear. Nice. From what I’ve read, you can instead run a wire to a reverse bulb since the unit is just looking for a signal when you’re going backwards.
Now I have to say that I was expecting issues or problems to be present here and there. From what I understand, Pioneer uses Microsoft WindowsCE as the OS for the AppRadio. I’m pretty sure that having CE talk to an iPod or an Android is a huge mess! Anyway, I felt I could take the plunge and deal with any issues that came along thinking that Pioneer was developing this technology and should make huge strides as they go.
I have to say that their insistence on incorporating safety components has stripped away any functionality that we customize in our phones. It pretty much limits you to using their authorized apps when the car is not in motion. For the most part, I only play music which I load on my phone and that's about it. Having a phone interface and a map/GPS interface is nice. I have Torque and hope to use it on the screen, but other than that I really don’t have any other demands for this unit. Wishes would include being able to use the bigger screen to easily read webpages or watch videos on Volvo repairs :)
As I mentioned, my girls do have an iPod plugged into the unit. I don’t use it but I have seen them play music from it and I have to say it’s a little disappointing. If you skip forward a track, it takes about a second or two to display the track info. I’d be pissed if all I had was an iPod. One note about this; I’m pretty sure there’s an app to be loaded on the iPod and they didn’t load it so that may cause the issue. Also, since Pioneer only list iPhones as compatible, I’m not sure if that has anything to do with it. Again, I’m not an Apple guy.
There’s a website someone put up specific to Pioneer car audio and they have a forum specific to the AppRadios: http://avic411.com/index.php?/forum/62- ... appradio-2
Things that piss me off
So as I get older, I seem to get more and more cranky and it feels appropriate that I tell anyone near me about it. This is no exception.
Sometimes it doesn’t respond to a tap, or sometimes when you tap the Android icon, it scrolls the screen to the right. I had this problem before I applied the anti-glare film.
You have to leave your phone screen on. How dumb is that?! To make it worse; my phone uses more juice than the adapter can provide so no matter what I’m doing, I’m losing battery power. This is because of the phone and not the radio. The phone, since it uses the HML cable, is limited to getting 500 milliamps due to the pin-outs and it uses more than that. Since the theory is that you should never have to touch your phone, what’s the point of keeping the screen on?!
Volume control is odd in that the volume buttons on the phone affect the loudness in conjunction with the AppRadio buttons. I’m not an expert on HDMI but I was under the impression that it sent line-level audio signal and having the phone buttons control sound seems stupid. The volume control on the iPod does not affect the AppRadio.
There have been a few times that I’ve been near the car while the AR is on but not had the phone connected to the cable and I receive a call. I start talking but suddenly realize that it’s connected via Bluetooth and the voice comes over the radio speakers. Weird.
Even though I installed the PAC TR-7 to override the handbrake issue, the AR doesn’t actually let me use its screen to control the non-AR apps. When I touch the screen when running a non-AR app, I get a red X telling me I’ve been naughty. I have to use my phone to run everything and simply watch the screen. What’s even more frustrating is that I sometimes get the red X when I’m running their apps!
It appears that the GPS antenna is activated only by the ‘authorized’ map program so I lose GPS signal all the time when using the map program from Sprint that came with my phone. That totally sucks since it’s much better than what they’ve done to Google Maps.
Speaking of Google Maps, their implementation is horrific. It crashes when you try to look-up a contact. You can’t display a map without all of the text boxes covering half of the screen. If you touch the screen for any reason, it’ll revert back to a map instead of a satellite image. Also if you touch it for any reason, it’ll lose its setting to stay centered on you. Worst of all (and this is Google’s fault) there’s no voice for the turns. You have to look at the screen to figure out where you are and what you have to do next. That takes your eyes off the road too much. Sprint gives me “TeleNav GPS Navigator” and it’s really good. I just want to use it!
Their music program is almost as bad. When it starts, you see a list of songs alphabetically, not a Play button as one would expect. The button to get to the screen where you can hit the Play button is so small that it takes several attempts to tap it before it works. I blame the small size as well as the app not responding quick enough. You can also just tap the ‘shuffle’ button and it’ll start playing a song. Play lists are easy to create but so difficult to manage that it’s not worth the effort.
It takes a moment or two for the phone & AR to sync up and get ready to work. Sometimes it's too long, and sometimes it craps out and doesn’t work at all.
You have to install their keyboard app which doesn’t have a voice-command button. I’m not sure when I need to actually use their keyboard, but it makes no sense to have a separate keyboard app. I’m guessing it’s all part of their corporate legal team being paranoid that they may get sued for some idiot not paying attention when they drive.
Last thing I can think of that pisses me off; there’s a ground whine that I can’t get rid of. When the lights dim, it changes tone. When the 4C suspension makes a noticeable adjustment, it changes tone. When you turn off the unit or unplug the phone, it goes away. I pulled the unit and did some testing with a grounding strap but still have the same problem. I’m not totally convinced it’s the fault of the AR but it sure doesn’t help the situation.
Light at the end of the tunnel
I don’t expect Pioneer to make the vast improvements necessary to meet the market demands, but there is hope; an app for the Android - ARLiberator for AppRadio – appears that it will let you use the AR “as expected”. I’ve not installed the app but plan to very soon. If you do some Googling, you'll find some videos on YouTube of people that have installed it and show how well it works. The app is $35 and requires you to root your phone. I was able to find a few videos on YouTube on how to root it and it looks pretty easy. I'm about to pull the trigger on this. I’m not sure if I would still need the PAC TR-7 after this app is installed, but I believe I would not.
Summary
I dunno, it’s all a royal pain that Pioneer isn’t making any major improvements. Because ARLiberator is available I don’t plan on replacing it but as it stands now I do get cranky once in a while when I’m using it. Plus, with all the additional expenses I put out for it and the level of frustration, it's been hard to think about the additional expense of completing the installation with the rearview camera, dimmer switch and the steering wheel controls. I’m a single guy and really want something to have a boom-wow-cool factor when I’m on a date, you know?! I'm pretty sure the ARLiberator will bring a Zen-like calmness to me soon. I’ll keep you posted.
Parts used:
Scosche VO4152B 2005-2007 S60/S70 ISO Double DIN - https://www.amazon.com/gp/product/B0018BQT6O
Metra Volvo Antenna Adapter (40-VL10) (40-VL10) - https://www.amazon.com/gp/product/B000329HFE
PAC TR-7 UNIVERSAL TRIGGER OUTPUT MODULE - https://www.amazon.com/gp/product/B004XJGQMA
Lexerd - Pioneer AppRadio 2 SPH-DA100 TrueVue Anti-glare In-Dash Screen Protector - https://www.amazon.com/Lexerd-AppRadio-S ... B00B9FKBE0
Aftermarket HU to Volvo Factory Amp Cable - http://www.omnilam.com/cables.html
Metra 70-9221 Radio Wiring Harness - https://www.amazon.com/Metra-70-9221-Rad ... B0002BEVAW
What I should have bought for the power adapter:
So the adapter kit from Pioneer is nothing more than a power adapter that gets hardwired to the car and plugs into a HDMI to HML adapter cable. All you need is a Micro USB to HDMI MHL Adapter like this one: https://www.amazon.com/gp/product/B005F9W6DU - I’ve not bought this one nor am I associated with it, just found it quickly. You’d also need to get a USB charger and either deal with it hanging out of a cigarette lighter or get it hardwired and hidden. Issues I see with this particular MHL adapter are that the wire length is very short (the Pioneer kit is like 18 inches long) and since the USB plug is on the side, it’ll get a little bulky. At the moment I have the adapter wedged between the center console and the driver’s seat. The wire lays over the e-brake handle when not in use and is sorta hidden because everything is black. Once the phone is connected, it sits on my lap or in a cup holder since I have to touch the screen once in a while.
What I want to do is get a docking station and have it installed where the nav screen pops up. But, if I can use ARLiberator and never have to touch the screen, then there’s no need to keep it in reach and I’ll probably do one of two things; one is to just make a small hole in the map pocket on the driver’s seat, pull the cable through it and leave it hidden in the pouch while I drive. The problem I see with that is the screen still has to be on and any movement may cause the screen to be touched. I also had the idea of mounting a docking station on the driver’s side of the center console, low over the slim kick panel that can be removed. That way it’s easy to reach from the driver’s seat but completely out of the way. My leg may brush against it, but I think it'd be a smart spot for an install.
1997 855 GLT - R.I.P.
2006 S60R - For ME!
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
Vince, this is outstanding. Going in the repair database within 24 hours.
Also -> Amazon link
gbrooke
Year and Model: 1998
Post by gbrooke »
try soldering a ground wire to your rca cables at the back of the radio and then ground that to the chassis. i have a pioneer dvd nav unit that had the dreaded whine and it almost drove me crazy for a year, finally broke down and did this and also took the ground wire from the radio and grounded it to the same spot and not to the wire in the car harness. problem solved for me
g brooke
vjaneczko
Post by vjaneczko »
You know, I grounded the radio chassis but not the RCA connectors. I'll have to give that a try. Thanks!
2006 S60R - For ME!
gbrooke
Post by gbrooke »
try and ground everything to one spot and don't use the ground wire in the radio harness from the car, take the black wire on the radio, the ground you add to the rca and radio chassis and ground it all to one spot, i'm pretty sure the main culprit is radio ground wire attached to stock wire harness ground. never had to do this with any other radio except this pioneer
g brooke
mandomex1
Year and Model: 2004 V70 2.5t
Post by mandomex1 »
Nice write up! Are there any software/onboard computer issues with the car and the aftermarket stereo? I've been reluctant to upgrade my headunit because I've read that the car's computers will freak out if the OEM unit isn't recognized with the steering wheel radio controls. Or is that just a Volvo urban legend? Thanks!
2004 V70 2.5t 111,xxx miles
1990 240DL stuck at 158,xxx miles
vjaneczko
Post by vjaneczko »
The steering wheel controls – and even the light dimmer switch – are not analog devices, they’re part of the massive CAN-Bus computer that ties into everything on the car (can anyone say “SkyNet”?!). Unfortunately, the radio is still analog so in order to use the controls or dimmer, you need to buy two separate adapters. From what I understand, the control adapter is around $50 from Amazon - the Axxess Metra ASWC-1. Not sure about the dimmer switch adapter.
So for the moment I have a bright radio at night and buttons on my wheel that do nothing. I’ll get to ‘em one day. The only ‘issue’ I’ve heard of is that when removing the panel that holds the radio & AC control panel, you need to disconnect the battery. The reason being that if you pull the power cable off the AC panel, it’ll throw the SRS code which disables the airbags and can only be reset by a dealer.
2006 S60R - For ME!
cbf295
Year and Model: S60R, 2007
Post by cbf295 »
HI, new member here, but I have been viewing since I bought my Volvo. Great post, lots of good information on what parts are needed as I try to upgrade my head unit. I've been looking to upgrade my HU-850 on my 2007 S60R. I have the premium system with amp and 6 disk in-dash cd changer. I'm just looking at replacing the head unit using either a Pioneer, JVC or Clarion. I'm not handy at all when it comes to electronics so I've contacted a couple of local car audio installers and have received some discouraging results. The installers seem to think that the climate controls are lost if I replace the head unit. They have also mentioned the brakes. They have shown me the schematics for the wiring and they seem to be referencing the brake control module and climate control module that are connected to the head unit in the schematic. The only flaw I can find in their assessment is that the schematics only show 9 speakers and I have 13. Has anyone else heard of or come across this?
vjaneczko
Post by vjaneczko »
Yup - they don't know what they're talking about. It's a shame, too, because it's not complicated. The big difference between my '06 and my '97 is that you need to disconnect the battery from the '06 to ensure you don't trip the SRS warning - which happens if you disconnect the power cable from the HVAC control board. Why is the SRS tripped if the HVAC panel losses power? No clue. It's kinda stupid to have them tied together but . . .
Anyway, the work is pretty easy to do yourself, just Google it and you'll find a few write-ups with pictures to get you through it. Get the wire harness and the double-DIN bracket and you're half way there.
2006 S60R - For ME!
MikeinNH
Year and Model: V70, 2003
Post by MikeinNH »
Thanks for this!
A couple of questions on wire routing. Where did you place the GPS antenna and the microphone, and how did you run the wires from the back of the unit - did you need to cut anything?
And how are you planning to run the cables for the backup camera?
(I'm about to install an older AVIC F700BT into a V70.)
