climate recirculation switch
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
ehofmeister
Year and Model: 240 dl wagon
Post by ehofmeister »
Hi, on a 1993, 240 DL wagon this winter I have a lot of moisture in the car. For example, drive to work on a cold day, park all day and I come out and there is a lot of moisture condensed on the interior of the windows. I try to keep the mats dry, run the defrost all the time and still there is a lot of moisture. I'm wondering if the recirculation is stuck on so it's trapping all the moisture inside the car. Is there a way to trouble shoot this?
thanks e
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Unfortunately there is no easy way to diagnose the manual heating system used in the 240. However, one problem that has arisen which can cause excess moisture in the car is a blocked, or partially blocked, heater unit drainage hose. Attached is a Volvo Service Bulletin addressing this.
240 heater unit drain hose.pdf
(586.73 KiB) Downloaded 135 times
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
