I am having a weird rattling sound coming from the passenger side of the engine - where the timing belt is. It happens only when the engine is cold and disappears almost completely when it warms up.
It is noticeable at idle and low RPMs (it gets louder when I pump slightly the acceleration pedal). I tried removing the accessory belt - the noise is still there, so it is not the AC, alternator or power steering. Also I replaced the timing belt and all it's components, EXCEPT the water pump recently (~20k miles ago). The car has ~125k miles currently.
That rattling started recently - maybe in the last 5-6k miles.
It sounds like there is something is loose and rattles - metal rattling sound. It is difficult to say where it is coming from, but my guess is from the crankshaft pulley area.
Also I recently removed the Timing belt cover to inspect the TB tensioner and the idle pulley for vibrations, but they were fine. Any idea? I believe it is getting louder and louder in the the last few months. I am out of ideas already. Thanks for any help.
2002 V40 Metallic rattling noise from engine when cold
rmmagow
- Year and Model: V70 1998
- Been thanked: 2 times
If you can run your engine with the timing belt cover off, do so and observe the timing belt tensioner to see if it it shaking around. Barring that, check any and all heat shields associated with the exhaust system. Try to wiggle the crankshaft pulley too, maybe it came loose. You should be able to see that shake too.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
I did that - nothing abnormal - the TB tensioner is not vibrating. Tried to check the crankshaft pulley for any play but since it is under tension from the timing belt - I don;t notice any. And when engine is running - no play in the crankshaft pulley.
Some update: I still have this sound on my Volvo, and I was able to record it:
https://dl.dropboxusercontent.com/u/748 ... _sound.mp3
At some point I started thinking if this could be the water pump? As far as I know if there is a noise from the water pump, it would be constant and would not change when the engine warms up, and it wont be rattling.
Again, I removed the accessory belt (no alternator, PS pump, AC compressor involved), and the sound was still there.
Hope anyone has an idea what could that be.
Smithandbacon
- Year and Model: 2002
I'm wondering if I have the same car. I have possibly the exact problem. Have you figured it out yet?
My user's manual says the noise comes from automatic valve clearance adjustment gear which uses oil pressure. So up on starting the engine the noise will last several seconds until oil gets every part of engine. In some cases this will last about 15 seconds (as I remember).
LT South Africa
- Year and Model: 2003
I have a similar noise. What i have noted is that the tensioner pulley does shake around with the motor spinning.
- 490 Views
Last post by Markus123
- 775 Views
Last post by Randall0208
- 522 Views
Last post by jonesg
- 2122 Views
Last post by CoupeC70
- 1879 Views
Last post by Marilyn99
