Gentlemen,
96 volvo 850, today I replaced the following:
Outer tie rod (TRW)
sway bar end link (IPD blue or HD)
Struts (all parts involved in strut replacement).
CV Joints are fairly new (EMPI).
During test drive, passenger side, I keep hearing a clunk noise on all bumps on road! Control arm and ball joint look good which explains why I did not replace them. Smooth ride but the clunk is ruining it!
Suggestions please.
clunk, clunk, clunk, after replacing front end parts.
bronxnativ
- Year and Model: 96 850 GLT 5 Speed
Al
- Year and Model: Many Volvos
- Been thanked: 76 times
Double check the sway bar end links. They have a tendency to bind up as you install them and torque them down. You may think it is tight but it isn't. You can usually feel a loose nut by feeling the joints, upper and lower, with your hand as someone bounces the front end up and down.
bronxnativ
Ozark Lee wrote:Double check the sway bar end links. They have a tendency to bind up as you install them and torque them down. You may think it is tight but it isn't. You can usually feel a loose nut by feeling the joints, upper and lower, with your hand as someone bounces the front end up and down.
Thanks Lee, will do so tomorrow first thing. Do you have the torque setting for the sway bar end link (anyone?). I don't have the book for it.
Al
JRL
- Year and Model: Several
- Been thanked: 16 times
I sure hope you replaced the spring seats.
Just removing and replacing them could be enough to break them
- Has thanked: 312 times
- Been thanked: 818 times
Officially, torque is 50 Nm. But really tight will work, too.
bronxnativ
Thanks Eric! Really appreciate it.erikv11 wrote:Officially, torque is 50 Nm. But really tight will work, too.
Al
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
The sway bar and control arm bolts are always difficult to torque down with a torque wrench.
I put a jack under the control arm and raise it to ride height and then snug down the bolts, or else they kept knocking on my car when I replaced the links.
Just tightening it really, really hard would probably work too.
'98 S70 T5
2016 Chevy Cruze Premier
bronxnativ
thanks to all that assisted! Lee, your advice was spot on (as usual). Tightening it down as stated by Lee and Justin is what did it! No torque wrench used as their is no space, but I did tighten as stated.
Al
- 719 Views
Last post by 93Regina
- 4074 Views
Last post by Beck
- 1845 Views
Last post by estrekal
- 33 Replies
- 11173 Views
Last post by bmdubya1198
- 11 Replies
- 3364 Views
Last post by michaelunderway
