gauge cluster issues
My fiances 98 c70 2.3 is having a odd issue with the gauges they will work fine for about twenty minutes and then they die, the digital information at the bottom of the cluster and lights will still function but speed, tach, temp, and oil pressure all die this happens both when the abs and traction off lights are on or off we have resoldered the abs module and also replaced the module. She has sunk a ton of time and money into this car any advice or ideas is greatly appreciated. Thanks in advance
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Jiggle the key in the ignition switch. I believe you have a bad electrical portion of the switch.
'98 S70 T5
2016 Chevy Cruze Premier
- Has thanked: 1611 times
- Been thanked: 4072 times
I have a similar dash cluster problem on my 1999 V70 T5
About once a month the speedo falls to zero, I get an idiot light or two come on, but tach, fuel and temp gauges all work
I've mapped tach speed to car speed in 4 and 5th gear to avoid tickets
Problem never last more than about 20 minutes before it resolves.
jblackburn
If it's that bad, the ignition switch contacts may be fried almost entirely once it warms up. I'd still try replacing that part. The ABS/TRACS lights alone are a definite indicator it's bad.
'98 S70 T5
Thanks...the ABS light always comes on when the speedo goes dead. 145k on the clock, 15 years old, so I will try the electrical part of the switch as suggested.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Ignition switch problems usually come with other issues with electrical problems like windows not working, turn signals not working, etc. There is a chance that you failed to fix the ABS module properly. Also, I had cluster problems and they were related to a bad wire on the harness that connects the cluster.
- 1513 Views
Last post by MDK
- 2139 Views
Last post by mydamnvolvo
- 4041 Views
Last post by Maxoner22
- 11 Replies
- 4391 Views
Last post by Faheyk1981
- 5064 Views
Last post by oragex
