Radio Code Blues
This topic is in the MVS Volvo Repair Database » Stage 0 and So Much More... Fix List for a V70
NoTunes
Radio Code Blues
Post by NoTunes »
Had a dead battery over the weekend. After restoring things back to normal, my radio now asks for a code.
I put in the four digit code - the one I found on a little card in the manual in my glove box. No dice.
I bought this car used - so I am not sure if this is the original radio - It is a Volvo OEM radio, but I dont think it is the one that came with the car.
Will the Volvo dealer be able to reset the code or do some such magic - or am I SOL ?
Thanks much for any advice.
Jot
Year and Model: C30 2010
Post by Jot »
Does the radio have "off" or "code" on the display? You will need to wait about 2 hours with the key in position II before you can enter the 4 digit #.
turbotim2
Post by turbotim2 »
Just a question, what would make the radio go into the "off" mode? I have unplugged the battery to do work on the car and then after plugging the battery back on, the radio just asks for the code which works fine.
2004 XC70
2005 S60 2.5T AWD (gone)
1996 850 GLT Wagon in Blue (gone)
1996 850 GLT Wagon in Green (gone)
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2663 times
Been thanked: 1256 times
Post by matthew1 »
turbotim2 wrote:Just a question, what would make the radio go into the "off" mode? I have unplugged the battery to do work on the car and then after plugging the battery back on, the radio just asks for the code which works fine.
Entering incorrect codes 3 or 4 times.
https://www.matthewsvolvosite.com/radio.php
Also -> Amazon link
NoTunes
Post by NoTunes »
Thanks for the reply Jot.
I input the code three times (apparently the incorrect code - DOH! ) and now my radio says OFF.
I definitely have the wrong code. It is not the one that corresponds to the VIN Number.
I wonder if the dealer can pull up a code if I were to give them the S/N off the radio..
Guest
Post by Guest »
If you push the two tabs on the radio you can pull it out and there might be a code written on the unit. Thats how I found my code when I had to disconnect my battery.
NoTunes
Post by NoTunes »
Thanks for your replies.
For future reference :
I went by the local Volvo dealer (Barrier Volvo Bellevue - Very Helpful Service Dept btw)..
Gave them the S/N of the radio (If you pull the radio out, there is usually a sticker on the top - the S/N is also stamped on the side). They got me the code in a couple of mins..
Had to wait two hours with the ignition on I for the radio to revert to CODE from OFF..
Code works ! Back to scheduled programming on NPR !
matthew1
Site Admin
Post by matthew1 »
Barrier and Ravenna are both very helpful dealers, I've found.
Also -> Amazon link
