850 N/A tb mod boring question..
I bored my intake to fit the larger na throttle on it. It isn't the most perfect job. Doesn't feel like a perfect smooth circle. Since the bit I was using was only about a centimeter in diameter, it cut deeper in some place making the bore feel kind of lumpy. It isnt terrible, i was going to try to clean it up with some 80 grit sandpaper to get some roughness out. What did you guys who did this mod use to bore it? As long as the hole is large enough to accept the TB does it have to be perfectly round and smooth? Thanks!
shaker_chi
- Year and Model: 94 850, 98 S70T5 M
- Has thanked: 3 times
- Been thanked: 3 times
So you bored out a turbo throttle body to fit the 960 plate? Just go to the junk yard and pick up an n/a throttle body and intake manifold.
Ben850
- Been thanked: 7 times
I believe he enlarged the manifold opening to allow an N/A throttle body.shaker_chi wrote:So you bored out a turbo throttle body to fit the 960 plate? Just go to the junk yard and pick up an n/a throttle body and intake manifold.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
- 1362 Views
Last post by Sveedy
- 1887 Views
Last post by EngineeringBloke
- 1890 Views
- 15717 Views
Last post by 93Regina
- 1908 Views
Last post by goVolvo
